Old 12-04-11, 10:24 PM   #1
Berlin
Default Shortening rear master cylinder stroke?
Is there any way of doing it?
I'm looking for half the peg travel I've got at the moment. I'd like to do it without moving the lever point.
Cheers, C
Old 12-04-11, 10:36 PM   #2
fastdruid
fastdruid's Avatar
Default Re: Shortening rear master cylinder stroke?
Change the master cylinder for one with a larger bore.
Druid
Old 12-04-11, 11:08 PM   #3
Berlin
erm.. Is that Minitwin legal?
Old 12-04-11, 11:10 PM   #4
fastdruid
fastdruid's Avatar
You tell me.
You could also extend the lever (where it connects to the M/C) and offset the M/C but that's way more grief.
Druid
Old 12-04-11, 11:11 PM   #5
Berlin
"Front and rear master cylinders must remain as originally produced by the manufacturer for the homologated machine".
Nope
Maybe I can compress the cylinder somewhat before the stroke starts. So effectively it's already pre-depressed but not causing the pads to touch the disk? This is what I'm looking for. So the pads hit the disk sooner in the peg stroke.
C
Old 12-04-11, 11:14 PM   #6
fastdruid
fastdruid's Avatar
I'd check to see if the curvy or pointy has a different M/C if you can exchange between years of SV.
Otherwise its extend the lever and offset the M/C, depending on your rearsets it may be easiest to do this by moving the lever pivot point.
Druid
Old 13-04-11, 08:11 AM   #7
Rocket
How much movement have you got at the lever before the pads start touching? Might it be excessive pad knock-off or the seals causing the piston to retract too far into the caliper when the pedal is released? Worth a strip & rebuild with some silicone grease on the dust seal?
Old 13-04-11, 08:29 AM   #8
daved407
Can the rod be adjusted?
Braided hoses would firm up the feel.
Currently in Walkden, not Germany
Old 13-04-11, 09:16 AM   #9
Teejayexc
Wear thicker insoles ?
Old 13-04-11, 09:59 AM   #10
mikerj
C
This is a very bad idea. You will block the fluid return port by doing this, so as soon as the brake warms up a bit it will start binding. Then it will get hotter and start binding more until eventually it risks locks up.
Rear brake master cylinder Roberrrrt Stuff Wanted 2 28-06-10 09:41 AM
rear master cylinder Bibio SV Talk, Tuning & Tweaking 3 08-05-09 02:40 PM
Rear brake master cylinder BillyC SV Talk, Tuning & Tweaking 1 16-07-08 12:46 AM
Rear Brake Master Cylinder jpb Stuff Wanted 1 16-06-06 10:05 AM
What stroke/bore is the SV's front master cylinder? northwind SV Talk, Tuning & Tweaking 2 30-05-05 08:10 PM
