Old 19-05-11, 09:42 PM   #1
MisterTommyH
MisterTommyH's Avatar
Default Brake light not working.
Just taken my rear fairing off to fit a tail tidy and I think I caught the wire to the brake light (probably being too rough) now my rear light works but does nothing when the brakes lever or pedal is touched.
Any suggestions? Or do I need a new light unit? Of so where can I get one quickly? Need the bike next Thursday to go away.
MisterTommyH is offline   Reply With Quote
Old 19-05-11, 09:59 PM   #2
Default Re: Brake light not working.
Check all disturbed connections first, make sure the plugs are all inserted fully. Then check that there's voltage at the rear light plug on the loom when the lever/pedal is operated.
Old 19-05-11, 11:09 PM   #3
MisterTommyH
All the plugs are inserted. Not got a volt meter, but I'm pretty sure it was where the wires go into the light unit that i pulled, so I think it's made a loose connection inside. Maybe time to take advantage and get some clear lights?
Old 23-05-11, 06:29 PM   #4
MisterTommyH
Ahhhh still not working. Any more suggestions?
Old 23-05-11, 06:39 PM   #5
Stuuk1
Have you tried wiggling the wire while holding the brake lever? May determine whether it's a lose connection inside... Hopefully not too loose that it won't make a conection.
Old 23-05-11, 06:40 PM   #6
MisterTommyH
Aquired a new unit and it's the same problem. Trying to chase the wires back on the loom but it's a nightmare!
Old 23-05-11, 07:54 PM   #7
Tommy, you really need a meter !!
Cheaper to buy a basic meter than keep swapping parts when you don't need to
Seriously, a meter will help you find where the break is, the braking circuit won't be that complicated.
Live feed to brake (s) switch, switch live at / from switch to light is basically what it is.
You can get a cheap meter for a tenner.
Old 23-05-11, 08:07 PM   #8
MisterTommyH
Yup. That's on the list then. Found the break. Hiding under the tank of all places miles away from anywhere I touched!
Brake light not working help adw SV Talk, Tuning & Tweaking 11 14-11-07 01:41 PM
Brake light not working help adw SV Talk, Tuning & Tweaking 0 14-11-07 09:34 AM
Brake light not working when rear brake is used.. StreetHawk SV Talk, Tuning & Tweaking 10 16-04-07 03:40 AM
Brake light stopped working! Aaron SV Talk, Tuning & Tweaking 7 01-03-05 06:01 PM
brake light not working with rear pedal Dirty Baz SV Talk, Tuning & Tweaking 8 20-09-04 01:36 PM
