Old 24-05-11, 01:26 PM   #1
davepreston
Default SV Thou rear wheel on a 650?
sv thou ,sv650
i assume i need different spacers but im more worried about the axel width
begin
Old 24-05-11, 03:16 PM   #2
flymo
flymo's Avatar
Default Re: can i throw a thou rear on a 650
you could possibly use the existing 650 axle by replacing the bearings in the 1000 wheel/sprocket carrier.
Is there enough room further forward for the wider tyre profile? Can the 650 caliper bracket be made to work with the new wheel?
Old 24-05-11, 04:16 PM   #3
Default Re: can i throw a thou rear on a 650?
Dave, time to get the verniers out.
Be similar work to doing a gsxr600/750 rear wheel conversion.
As I think the SV thou rear wheel is from a k1-2 GSXR (with different bearings), can someone confirm that?
Old 24-05-11, 04:19 PM   #4
Like I say, probably but not certainly a massive PITA.
Investigate chain offset, compare that to amount that can be machined off sprocket carrier and see if it is possible. I doubt it.
If you want 180/5.5 rear then zoran sells a nice kit to use K6> GSXR wheel very easily.
Old 25-05-11, 06:47 AM   #5
zadar
SV1000 wheel is same as older gsxr (01-03). It is to wide for 650. Rotor side is problem.
It is doable ( I did couple of them) but needs machining and new caliper hanger.
Old 04-12-11, 07:20 PM   #6
Fatboy SV
can this be done by fitting a sv1000 swingarm?
Old 04-12-11, 07:52 PM   #7
I don't think throwing will be good enough, it probably won't stick.
I suspect some bolts or similar will be required.
Old 04-12-11, 08:04 PM   #8
NTECUK
NTECUK's Avatar
Or Duck
Tape.
Old 04-12-11, 11:34 PM   #9
timwilky
timwilky's Avatar
FFS Dave stop get ideas
You have got the equipment to turn fantasy to reality.
PS I still need you to turn up astride the wife's noble steed.---- Wimp
Not Grumpy, opinionated.
Old 05-12-11, 11:19 AM   #10
punyXpress
punyXpress's Avatar
Next Question: can I throw a perfectly good SV650 down the runway at Leeming?
Now: Street Triple R
Does an 'N' rear wheel fit an 'S'? davepreston SV Talk, Tuning & Tweaking 8 11-05-09 01:25 PM
Cleaning all around the rear wheel / swingarm / rear brake caliper Camel SV Talk, Tuning & Tweaking 12 28-04-08 02:00 PM
cbr rear wheel yorkie_chris SV Talk, Tuning & Tweaking 33 20-02-08 11:09 PM
Thou rear wheel nut size Mark_h SV Talk, Tuning & Tweaking 6 15-02-08 02:55 PM
Next year's SV Thou' up to 118 bhp! - (at the rear wheel) howardr SV Talk, Tuning & Tweaking 4 03-11-04 03:16 PM
