Old 01-06-11, 08:50 AM   #1
Joeskeppi
Default Bolts on peg hanger keep coming loose
I've had to tighten the bolts on one of my peg hangers twice in the last month or so, at one point I couldn't change gear properly because it came so loose. What's the best way of making these things stay put?
Cheers!
Old 01-06-11, 08:54 AM   #2
jambo
jambo's Avatar
Default Re: Bolts on peg hanger keep coming loose
Threadlock.
It dries on threads and should stop them vibrating loose
Jambo
Old 01-06-11, 10:21 AM   #3
warmshed
http://cgi.ebay.co.uk/Loctite-243-50...item2eb58124f9
Old 01-06-11, 11:45 AM   #4
Irish ek
As jambo said above, Blue loctite works a treat. Will stop them coming loose!
http://www.loctiteproducts.com/p/t_l...r-Blue-242.htm
Old 01-06-11, 12:32 PM   #5
muzikill
muzikill's Avatar
Yup, they are threadlocked in the factory when they are built
Old 01-06-11, 02:46 PM   #6
Joeskeppi
Great, thanks!
Pinlok insert coming loose (XR-1100) thedonal Bikes - Talk & Issues 4 04-02-11 09:35 AM
Bolts working loose due to vibrations BigFootIsBlurry SV Talk, Tuning & Tweaking 3 10-06-09 08:46 AM
Catherine Wheel Final Whos Coming and "Other Bits" Thread - PLEASE READ IF YOUR COMING :-) 454697819 Pennine Massive 61 12-10-08 10:09 AM
gear selector coming loose Ollie_07 SV Talk, Tuning & Tweaking 10 12-05-08 02:35 PM
Leo Vince Loose Hanger... SpacemanSpiff Exhausts 3 26-03-06 10:29 PM
