Old 15-06-11, 02:00 PM   #1
davepreston
Default 1mm forks size differance can owt be done?
sv 1000 fork size 46mm
forks im looking at 45mm
now im no enginqueer but is this in the relms of being able to be done by widing the pinch slit on the yoke and tighting it more
begin the abuse
Old 15-06-11, 02:07 PM   #2
timwilky
timwilky's Avatar
Default Re: 1mm forks size differance can owt be done
Dave, think about it, You are starting with a rattle fit and as you stress the yokes to clamp it you will only be contacting the forks at two points and then bending the yoke round the rest of the fork. Asking for trouble, I would not think them stable
Not Grumpy, opinionated.
Old 15-06-11, 02:07 PM   #3
Icanopit
Hi DAVE, the correct method is to use some "shim material" and not put excess strain on the Yokes?? perhaps YC has some shim stock if not I will have a look through what I have if it helps.
JOHN
Old 15-06-11, 02:10 PM   #4
timwilky
timwilky's Avatar
Shimming would help. Personal opinion is it is a compromise. I would always be thinking that it is an extra interface that could let go
Old 15-06-11, 02:11 PM   #5
sv4me
sv4me's Avatar
Originally Posted by davepreston View Post
begin the abuse
You're a beanpole with a face only a mother could love........oh you meant about the forks
Old 15-06-11, 02:52 PM   #6
Default Re: 1mm forks size differance can owt be done?
why what are you planning and why?
No don't do it except with shim. Cast ally is not great for flexing.
Old 15-06-11, 03:15 PM   #7
jambo
jambo's Avatar
45 - 46mm diameter is only 1mm difference so sounds possible.
However, over the circumference of the fork / yoke contact patch that works out to be over 3mm of difference (Pi*46 - Pi*45)
That's a lot of stretch.
I'd be after something that fits, or a suitable way of making up the difference
Jambo
Old 15-06-11, 03:17 PM   #8
davepreston
ok idea shelved
dave im going to use you for dwarf bowling at AR
Old 15-06-11, 04:41 PM   #9
Shim will be fine as long as it's accurately sized.
is there a differance between 1000 and 650 tanks? widget Bikes - Talk & Issues 12 06-04-10 07:29 PM
differance between bike oil and car oil ricky SV Talk, Tuning & Tweaking 16 08-12-08 10:34 PM
whats the differance? Richie Idle Banter 13 20-02-08 05:04 PM
Is there a differance.... skapegoat Bikes - Talk & Issues 5 06-02-08 07:51 PM
spot the differance hovis Idle Banter 10 20-11-07 02:01 PM
