Old 30-06-11, 10:41 AM   #1
fastdruid
fastdruid's Avatar
Default Racing valve springs? (or not)
Finally getting a round tuit I took a look with regard to fitting the JHS cams I have, on measuring them though it appears that they are the "stage 3" cams
The inlets appear to be 0.7mm more lift than pointy inlets and according to http://forums.sv650.org/showthread.php?t=55203 should be fitted with race springs.
Seeing as the JHS racing SV650 'archive' which might supply some more info is no more, what say those that have more experience, get and fit race springs[1] or "WTF dude, just fscking fit them".
If its "get some" then anyone got any better suggestions than the ones from TWF[2]?
Druid
[1] Which may take some time, still it appears I have 4 inlets anyway so not all is lost.
[2] http://www.twfracing.com/PartsPages/ValveSprings.html
Old 30-06-11, 12:15 PM   #2
Fade
Default Re: Racing valve springs? (or not)
0.7 mm is quite a lot in terms of cam design, there is a chance that the stock springs could get coil bound and the dynamics could get a bit mental.
An good indication is to look at the cam durations if you can, if they are similar then kit springs would be a good idea, if the race cams are much longer duration you might get away with it.
Rgds,
Pete
Old 30-06-11, 12:19 PM   #3
fastdruid
fastdruid's Avatar
I've been told by someone that JHS played with duration etc on them as well but don't know by how much.
From another POV they have 1.3mm extra (intake) and 2.6mm (exhaust) over stock!
Druid
Old 01-07-11, 01:24 PM   #4
SV650Racer
We use stock valve springs on all our bikes from the mild tuned 650cc bikes right through to the 750cc stroked big bore bikes with no issues at all. The stock springs are very good IMHO.
Old 01-07-11, 02:17 PM   #5
fastdruid
fastdruid's Avatar
Interesting, what kind of cams are you running on them?
Druid
Old 01-07-11, 02:32 PM   #6
SV650Racer
Kent cams to our own spec to suit a higher rev limit. Not sure on the specs, steve isnt around at the moment
Old 01-07-11, 03:28 PM   #7
fastdruid
fastdruid's Avatar
I'd be interested to know the lift[1] to see if its a valid comparison, by PM if you'd rather keep it private.
Druid
[1] Although lift is not everything I don't expect you to give me exact timings, durations etc (and I wouldn't know what to do with them even if I had them! )
Old 01-07-11, 03:32 PM   #8
SV650Racer
PM sent
Any opinions on Firefox Racing? (formerly DPS racing) Keighley Whitty Pennine Massive 21 26-08-12 07:22 PM
Valve condition? barwel1992 SV Talk, Tuning & Tweaking 9 13-01-11 08:22 AM
Valve Clearances again! madness SV Talk, Tuning & Tweaking 25 28-01-10 09:42 PM
ex up valve hovis Bikes - Talk & Issues 12 06-08-08 08:35 PM
Valve Clearances - How 'Ard? Biker_Billy SV Talk, Tuning & Tweaking 19 19-06-07 11:04 AM
