Old 03-07-11, 09:01 PM   #1
muzikill
muzikill's Avatar
Default Plastic pipe size to fit fork seals?
without faffing around reading through threads does anyone know what size/length i would need?
ta in advance
Old 03-07-11, 09:22 PM   #2
BBadger
Default Re: Plastic pipe size to fit fork seals?
if its the oil seal....use the old one ontop and a punch then no damage to the new one. oh and dont forget to put abit of grease around the outside of the seal.
Old 04-07-11, 07:07 AM   #3
muzikill
muzikill's Avatar
ta, will the dust seal push on?
Old 04-07-11, 07:34 AM   #4
BBadger
yup again use abit of oil on the inside so its slides down the stantion and grease on the outside so it slots in easy.
will need abit of a push but nout to hard when i did mine.
[Edit]
make sure all the surfaces are clean a smooth helps alot to so a good clean and maybe fine grade wet and dry if theres any build up of crap you cant shift.
Old 04-07-11, 07:25 PM   #5
Winder
Winder's Avatar
Dont forget your brush pole with the finger off a rubber glove taped to the end!!! Ha ha. Bloody damper rod bolts took me hours to get off.
Old 04-07-11, 07:44 PM   #6
muzikill
muzikill's Avatar
yeah i was wondering whats to loosen before i took the weight off the front
Old 04-07-11, 09:27 PM   #7
Lozzo
2"/50mm plumbing waste pipe - cut about 400mm off and then cut it up the length. Using thick cable ties you can overlap the cut ends and adjust it to whatever diameter you need.
My local plumber chucked me a bit of waste (pun not intended) stuff he had laying on the floor of his van for free, I've had it about ten years now
Old 04-07-11, 09:30 PM   #8
Lozzo
Everything except the top yoke pinch bolts. Just loosen but don't remove anything until it's in the air, but leave those two tight to hold the whole forks assembly in place until you're ready to remove the forks.
It's easier and safer to do the loosening while the front is on the deck, saves the bike becoming unstable on its stands when you have to apply a bit of heft to a tight fastener.
OEM Fork seals - where from? CodeJACK SV Talk, Tuning & Tweaking 5 07-08-10 07:47 PM
What size is the plastic rivet that holds the lowers together? Nobbylad SV Talk, Tuning & Tweaking 11 26-03-09 04:28 PM
Fork oil seals, which way up? Ceri JC SV Talk, Tuning & Tweaking 5 04-03-09 07:33 PM
plumber advice, plastic pipe timwilky Idle Banter 20 11-08-08 04:29 PM
fork seals ruff_ryder SV Talk, Tuning & Tweaking 11 29-06-05 05:43 PM
