Old 06-07-11, 10:27 PM   #1
Lundy1993
Default Battery Problem
Hiya Guys/Gals
When i put my lights on they seem to drain my battery as the day after i cannot start my bike
Also my lights get dimmer when on long journeys
I have replaced my battery and have taken the following readings:
Fully Charged 13.17V
Battery at 5000 revs 15.15V
Idle 15.24V
I have not done the tests with the lights on yet though
I appreciate your help
Old 07-07-11, 07:05 AM   #2
Geese
Default Re: Battery Problem
15.24v sounds a bit high. Get these measurements
Engine off Volt
Engine idle V
Engine 5k V
Lights on Idle
Lights on 5k
Old 07-07-11, 07:50 AM   #3
mister c
mister c's Avatar
Curvy, or pointy?
Could be Regulator/rectifier. 15v does sound high, should be in the 14s when revved to about 3 - 4000rpm
Tick over should be in the 13s
Old 07-07-11, 08:21 AM   #4
Geodude
Geodude's Avatar
Sounds like reg/rec but give your connectors and earth a check over.
Have a look through this electrical diagnosis guide http://www.electrosport.com/media/pd...ng-diagram.pdf
Or have a read through my thread here http://forums.sv650.org/showthread.php?t=164281
Hope its of some use till the clever peeps come along
Old 07-07-11, 08:34 PM   #5
Lundy1993
cheers for advice guys
i think it is the R/R to be honest
It is a Curvy mate
just done the readings again today and was shocked
Engine Off 12.34V (Bearing in mind not been charged for a couple days)
Idle 18.01V
5000 RPM 19.04V
Lights on at Idle 10.31V
Lihts on at 5000 RPM 13.2V
cheers again guys
Old 08-07-11, 10:54 AM   #6
Geese
Wow normally battery threads go on and on and on..
Take the RR out and kick it across the field!
Battery Problem? lily Bikes - Talk & Issues 13 27-12-08 11:10 AM
Battery Problem butterick99 SV Talk, Tuning & Tweaking 9 23-06-08 10:30 AM
battery problem butterick99 SV Talk, Tuning & Tweaking 1 17-06-08 08:32 PM
Battery problem / Alternator problem? localhost SV Talk, Tuning & Tweaking 4 07-07-06 09:32 AM
Battery/Starting problem - new battery hasnt fixed it! Aaron SV Talk, Tuning & Tweaking 13 24-01-05 05:21 PM
