Old 10-07-11, 06:53 PM   #1
muzikill
muzikill's Avatar
Default Curvy 99-02. Fork, Dust and oil seals
2x Dust seals
2x Oil Seals
Bought off ebay a few months ago.. misadvertised here as 99-04 !?! - stupid idiot me should have realised it was wrong and order non-abs 03-07 ones
http://cgi.ebay.co.uk/Fork-Dust-seal...32595229564974
http://cgi.ebay.co.uk/Fork-Seals-Suz...item2eaf7b2c76
£10 all in with the p&p. Paypal only.
Old 13-07-11, 06:46 PM   #2
steveinhull
Hi ,
Have you sold these yet pls ?
Old 14-07-11, 07:00 AM   #3
muzikill
muzikill's Avatar
Default Re: Curvy 99-02. Fork, Dust and oil seals
still got them, still for sale.
Old 14-07-11, 11:59 AM   #4
farquare
Will these fit a 99-02 naked k1? If so i'll take them
Sent from my U20i using Tapatalk
farquare is offline   Reply With Quote
Old 14-07-11, 02:39 PM   #5
muzikill
muzikill's Avatar
As far as i am aware they are for exactly that. If they arent i accept returns
Old 14-07-11, 03:52 PM   #6
farquare
Pm'd can collect on the way home tonight if your about....
Old 14-07-11, 07:52 PM   #7
farquare
Payment sent, was nice to meet you. Hopefully you get the forks all back together.
Old 15-07-11, 08:58 PM   #8
muzikill
muzikill's Avatar
bike back together. sorted. well we will see after a few miles!. You may get a shout when i have the clearances to do. let me know how you get on with your forks. The workshops here if you get stuck.
Dust seals -brakes, where from? hannakournikova SV Talk, Tuning & Tweaking 9 28-04-11 08:16 AM
Dust AND piston seals? Alpinestarhero SV Talk, Tuning & Tweaking 17 27-01-09 08:06 AM
Dust Seals TSM Bikes - Talk & Issues 5 01-09-06 10:10 AM
Fork seals 2001 curvy. Blue_SV650S SV Talk, Tuning & Tweaking 2 29-03-06 06:17 PM
Brake Dust Seals leegriffiths128 SV Talk, Tuning & Tweaking 2 16-12-05 06:59 PM
