Old 11-07-11, 04:00 PM   #1
Chris Bird
Question Shock and Swingarm mod?
Can any one tell me if this would mount onto a SV650s k6?
Old 12-07-11, 08:44 AM   #2
Default Re: Shock and Swingarm mod?
Nope
The shock isn't in the right position for a SV
Old 12-07-11, 09:12 AM   #3
davegixer1300r
You would not be advised not by me as the busa weighs twice that of the sv so spring rate would be all wrong even if it were to fit
Old 12-07-11, 11:57 AM   #4
Chris Bird
Okay cheers guys. Basically I'm looking in to the possibility of trying to increase the spring rate and rear ride height as I'm 15.5 stone and over 6ft. Not sure of the best way to go about it.
Old 12-07-11, 12:14 PM   #5
The shock would be a good place to start
Old 12-07-11, 12:38 PM   #6
Chris Bird
From what I've found so far, K3/K4 and possibly K5 have a good amount of stiffnes. A 636 or zzr 1400 shock for heavy guys and an 06/07 ZX10r shock will raise the rear ride height.
Anyone know of one that will do both or am I being a mong?
Old 12-07-11, 01:32 PM   #7
davegixer1300r
Question of pennies really you can get shockers specifically for the SV that can/will be set up for your weight and are adjustable to suit conditions and style. A lot of people seem to want fit gsxr 600 shocks
any supplier to the minitwin brigade will help or advise you. Maxton Ohlins Nitron Hagon just email them with your requirements it costs nowt to find out.
Old 12-07-11, 02:28 PM   #8
BaP
I have a B1h 636 shock for sale.
It's too stiff for me, 9.7kg/mm and I'm 11.5 stone. It also raises the ride height by 10mm, which is bad 'cus I'm short.
Old 12-07-11, 02:57 PM   #9
Viney
Shorty Lightwieght. Im 6ft 2" and wiegh over 16 stone and run a standard sv shock and have done for 72000 miles (although its been replaced a couple of times in that period)
I do have the rear raised about an inch though through fitting shorter links(dog bones)
Old 13-07-11, 09:23 AM   #10
Peachey
For the same reason I was going to do the Kwak rear shock mod, i had researched this quite alot and recomend you do the same. You need a shock from a 06/07 ZX10R. I even got as far as buying the shock, but have opted to buy a new bike when I'm back from my France Tour in a couple of weeks.
Mod details. http://forum.svrider.com/showthread.php?t=80387
Shock for sale. http://forums.sv650.org/showthread.php?t=168657
Regards,
Peachey.
Ohlins shock for pointy model Sv650 Near new, genuine sv shock!! sv650k4 For Sale - SV's and SV related items 9 13-07-11 08:02 PM
Rear shock and swingarm ianhaigh Bikes - Talk & Issues 4 09-06-11 06:39 PM
gsxr 750 srad shock rubs on curvy swingarm, help? leebex SV Talk, Tuning & Tweaking 22 21-11-10 09:02 PM
rear shock nut and bolt for a diff shock drag Stuff Wanted 0 22-04-08 03:52 PM
trick swingarm,shock for a curvy gruff SV Talk, Tuning & Tweaking 2 02-10-07 01:04 PM
