Old 14-07-11, 08:24 PM   #1
damob
Smile SV indicator conversion
Hi all , I have just bought a 2009 sv650 which has had an indicator conversion. so the indicators are now in the headlights. since picking it up have noticed the indicators are flashing a lot quicker that excepted. Has the conversion been done wrong or is it just due to the bulbs being used? if anyone has any info , would be much appreciated Damo
Old 14-07-11, 09:15 PM   #2
MisterTommyH
MisterTommyH's Avatar
Default Re: SV indicator conversion
Try searching for 'flasher unit'
MisterTommyH is offline   Reply With Quote
Old 14-07-11, 09:23 PM   #3
Kilted Ginger
if they are leds and an aftermarket flasher has not been fitted then fast flash. however iirc 120 flashes per min is allowed for mot. I'm sure someone will be along to correct me soon.
Old 16-07-11, 09:02 PM   #4
damob
Checked them today there defiantly not LED's , also if you put the hazards on all indicators flash at the corrcet speed.
Old 17-07-11, 11:49 AM   #5
Stonesie
If they have used standard sidelight type bulbs like cars use in the side repeater then they are only 5 watts, normal indicator bulbs are over 20 (23 for a bike?) so there could be your problem, a LED flasher relay will sort it out and means if you ever decide to use LED rear indicators then you can just plug them in and away you go (no resistors required).
Old 17-07-11, 11:53 AM   #6
SoulKiss
SoulKiss's Avatar
Please also note that due tio the proximity of your headlights, they will be next to impossible to see, and I think (without taking a ruler to my SV right now) they will be too close together, making them illegal.
I considered this mod, but then realised I liked things like being able to walk and breathing.
Old 17-07-11, 12:10 PM   #7
ophic
ophic's Avatar
I looked at it a few years ago and I agree with SK. 5W is just too dim. Fitting brighter ones might melt the rubber mounts, and I don't think you can get anything brighter that fits directly. LEDs would probably be ok but they weren't around much back then.
Silver SV650SK3, Fuel exhaust
Old 17-07-11, 12:11 PM   #8
damob
Cheers guys much appreciated .
Old 19-07-11, 07:50 AM   #9
maxinc
Very dangerous mod IMHO. I seriously doubt that anyone could distinguish the flashing LEDs or low power bulbs next to the bright headlights especially at night. I considered at some point an indicator mod but the safety aspect really put me off.
Old 19-07-11, 08:37 AM   #10
RichT
You can buy an aftermarket relay on the bay that's a direct replacement for the OEM unit under your pillion seat if required for LED's. There's a UK supplier (you don't need to get it from Germany) and it's about £20 IIRC...
I did the same conversion to my bike and it sorted the disco effect out a treat.
You do have to choose powerful bulbs so they are seen above your headlight during daylight hours, but I also kept side repeaters... It might be worth looking into this if yours have been removed.
Which HID Conversion? SVS. danf1234 SV Talk, Tuning & Tweaking 30 06-11-11 06:03 PM
Conversion from 'S' to 'N'? Heresiarch SV Talk, Tuning & Tweaking 9 07-03-11 06:52 PM
ROCA indicator conversion zigrat SV Talk, Tuning & Tweaking 2 02-04-09 08:33 PM
Rocha Indicator Conversion Kit mike_b Stuff Wanted 0 26-12-05 05:55 PM
K5 Indicator conversion MarkyBoy Bikes - Talk & Issues 2 26-07-05 09:47 AM
