Old 20-07-11, 01:47 PM   #1
AndyBrad
Default oil filters
Does anyone know (or have a preference, and why) as to whichoil filter is better or are they all the same. Im looking at k&n hifo andfiltrex atm as they are all around a tenner and the triumph one although itlooks nice is looking like an extrea 5 quid.
Soo any thoughts?
Old 20-07-11, 01:59 PM   #2
rictus01
rictus01's Avatar
Default Re: oil filters
I use Hiflo, I get them from a seller off ebay half a dozen at a time, I contacted him and got a special rate for bulk orders work out just over £5 each, he sells them for about a pound more each, work fine and it means I can use a new filter each oil change.
Cheers Mark.
Old 20-07-11, 02:01 PM   #3
ThEGr33k
Hiflo here too. seem to work fine.
Old 20-07-11, 02:03 PM   #4
AndyBrad
tbh i cant see why you wouldnt use a new filter every oil change!
yea used hiflo before and k&n just wondering if there is actually a diff?
Old 20-07-11, 02:10 PM   #5
rictus01
rictus01's Avatar
much depends on how often and how your bike is used, my oil changes are normally around 3-3.5k,but it generally does hard work on it's runs, although not as many heat cycles , I think Triumph state 4k for the S4.
Old 20-07-11, 02:14 PM   #6
AndyBrad
Yea 4k for the speed four. I doing it at 3.5k this time though as i used comp4 (silkoline 15w50) last time and the bikes not liked it imo. I think its a lot happier with the fully synthetic stuff.
Old 20-07-11, 02:16 PM   #7
AndyBrad
Forgot to ask, do you take your swing arm out rictus to grease all your suspension linkages etc?
Old 20-07-11, 02:18 PM   #8
rictus01
rictus01's Avatar
As I just replied on FB, mines had Elf 4XT tech the last couple of times, but normally the HG semi works without problem, dam sight cheaper to.
Old 20-07-11, 02:29 PM   #9
rictus01
rictus01's Avatar
not all the way no if I'm only doing the pivot, I slide the bolt out one side grease that, then put a short bolt in that side and remove the original to do the other side.
I've had the whole thing apart last year but I was doing everything then, so the shock came out as well.
Old 20-07-11, 02:40 PM   #10
AndyBrad
Yea i tried semi this time. (i want to keep the 15w50 as it will cope with sitting in traffic better) but its just seemed a little noisier using the semi. Seems as though its not as crisp either. Lets hope the mobil will help things. The putoline fully synth seemed ok at reasonable prices.
Good idea with the bolt. Think im going to take mine appart this winter and maybe get the shock rebuilt as well. Just wondering if you did it as part of your 8k service?
K&N Oil filters SV400Rob SV Talk, Tuning & Tweaking 12 11-03-11 05:36 PM
Pod Filters phizog SV Talk, Tuning & Tweaking 17 17-11-07 09:10 PM
K&N, BMC Air filters Grinch SV Talk, Tuning & Tweaking 11 23-04-07 07:46 AM
Oil filters svrash SV Talk, Tuning & Tweaking 11 03-01-07 10:30 AM
k&N filters 01 sv650s SV Talk, Tuning & Tweaking 2 24-10-06 04:03 PM
