Old 21-07-11, 07:45 AM   #1
krhall
Default MOT Failure?
Is a broken rear windscreen wiper an MOT failure?
Old 21-07-11, 08:02 AM   #2
Quedos
Default Re: MOT Failure?
a rear wiper is not a testable item so should not fail on that
* i take no responsibilty if you do fail mind you
useful link for you HERE
Old 21-07-11, 08:04 AM   #3
krhall
I have one on order from fiat (yep only available from them, full arm not just blade WTF?)
Old 21-07-11, 08:04 AM   #4
as Q
Don't think its in the requirements, as the transit connects are classed as cars and the rear wiper is optional
Old 21-07-11, 08:07 AM   #5
krhall
I sort of thought that. It is the wife's car and I have been asking her for the last month - 6 weeks about when her MOT is due and finally found out - NOW!
So two new front-tyres needed and a new wiper arm for the rear, oh and she needs tax too!
Old 21-07-11, 08:34 AM   #6
caz650s
Rear wiper / washer not a testable / failable item ... some testers may put it down as an advisory .
Put the new tyres on before you present it for the test ... at least the tester will know you try & keep your car in a safe condition !
I hate it when i test a car with bald tyres or other obvious faults & when it fails they say yeah i thought it would fail on that !!
best of luck
Caz
Old 21-07-11, 08:36 AM   #7
krhall
Tyres sorted only one really need doing but the other was close and as they are fronts on a front wheel drive car, decided to do both!
Old 21-07-11, 08:38 AM   #8
Swap them with the rears.
Me old used to do that when the test was due
Old 21-07-11, 08:43 AM   #9
krhall
Thanks all. Test now booked £25, thanks to Mr.Clutch.
Old 21-07-11, 06:36 PM   #10
leebex
www.shop4parts.co.uk is very good for fiat and alfa parts, used them for both makes myself in the past
MOT failure dirtydog Bikes - Talk & Issues 26 26-04-09 12:16 PM
MOT failure pinman Bikes - Talk & Issues 46 22-04-09 09:27 PM
MOT Failure melody Idle Banter 33 24-02-09 03:06 PM
Failure Dicky Ticker The Essex Lounge 14 30-10-08 08:52 PM
What a con! – MOT failure Blue_SV650S Idle Banter 30 25-05-07 07:11 PM
