Old 04-08-11, 09:27 AM   #1
BoltonSte
Default Consequences of higher wattage bulbs
So I've been looking at changing the bulbs on the Street.
I've looked at nightbreakers etc, but what would be the consequences of just uping the wattage?
The lights are the bug eyes, like the naked, they are glass with a plastic (I believe) reflector.
I know that high wattage bulbs without UV filters will yellow plastic lenses (shouldn't be an issue)
Also there will be more draw (these have been run in cars without issues other than yellowing)
Is there anything else that I should be cautious about?
Ste
Had an SV or three.
Street triple R - gone but not forgotten.
Now trying the lunacy that is KTM with a Superduke GT. for the pillion capability of course.
BoltonSte is offline   Reply With Quote
Old 04-08-11, 09:53 AM   #2
Luckypants
Luckypants's Avatar
Default Re: Consequences of higher wattage bulbs
Originally Posted by BoltonSte View Post
Also there will be more draw <snip>
Isn't that enough? Drawing more current will heat the wires, switches and contacts more than a standard watt bulb. This could lead to premature failure of the headlamp circuit or even a fire. If the headlamps are 'class' why do you need higher wattage bulbs? Think carefully about what you want from upgrading your bulbs...
Old 04-08-11, 12:15 PM   #3
NTECUK
NTECUK's Avatar
We had a.numpty fit 150/100 bulbs to there Micra melted the ipdm. New Unit and h lamp connectors ,refit old bulbs .400 notes later he was back on the road .....
Old 04-08-11, 12:39 PM   #4
Twed650
i put a normal car sidelight bulb onto my husky (original bulb was 3W) and melted the sidelight harness! just a few watt's difference.
took me hours to strip out the wires from the loom and put new ones in...
Old 04-08-11, 01:33 PM   #5
hindle8907
hindle8907's Avatar
Ste
Will Bolton council not have something to say about that ?
Old 04-08-11, 01:49 PM   #6
Twed650
Originally Posted by hindle8907 View Post
Won't Bolton council have something to say about that ?
i'll get your coat for you...
Old 04-08-11, 02:06 PM   #7
hindle8907
hindle8907's Avatar
ta
Old 04-08-11, 02:18 PM   #8
maxinc
Get HIDs. Much better light output than any incandescent bulb and they run cooler while drawing less current.
Old 04-08-11, 03:29 PM   #9
You should be able to put a marginally more powerful bulb in the lamps without any issues. They'll be 40-50w in as standard (most are)
That is all on HID's
Old 04-08-11, 03:34 PM   #10
Twed650
yep, think they only run on 35W.
Different wattage headlight bulbs? Jamesy D SV Talk, Tuning & Tweaking 12 02-05-10 10:13 PM
Higher bars on an N aermacchi SV Talk, Tuning & Tweaking 1 07-07-08 05:11 PM
higher watt bulbs. BIKER-DENE SV Talk, Tuning & Tweaking 17 18-03-06 06:15 PM
Higher bars. BURNER SV Talk, Tuning & Tweaking 7 12-07-05 03:20 PM
Headlight wattage - SV650S Y Import sosh SV Talk, Tuning & Tweaking 0 11-04-05 12:34 PM
