Old 05-08-11, 10:09 AM   #1
-Ralph-
Default Balancing wheels on the bike
Is it possible? ie: with the bike lifted off the ground and the wheels fitted to the bike (chain removed from the sprocket at the rear) will the wheels turn freely enough on the wheel bearings for gravity to expose a heavy spot in a tyre?
I know it would depend on how heavy the heavy spot is, but lets say 10 grams or more, significant enough to cause a vibration.
Assume free running and properly greased wheel bearings.
I'll try it at the weekend by sticking a 10 gram weight on a balanced wheel and see if it turns, until then, any thoughts?
Thanks
Old 05-08-11, 12:47 PM   #2
beabert
Default Re: Balancing wheels on the bike
I couldn't, was ages ago, so cant remember which bike i tried it on. If you have success, ill be trying again.
Old 05-08-11, 04:29 PM   #3
hardhat_harry
No its not.
Old 08-08-11, 11:35 AM   #4
No, too much drag from dust seals and stuff.
Old 08-08-11, 03:29 PM   #5
mikerj
With completely worn out seals, very loose bearings, pads levered away from the discs and the chain removed etc. it might sort of work on the rear. On the front you have the additional drag of the speedo sensor.
Old 08-08-11, 06:50 PM   #6
muzikill
muzikill's Avatar
id be interested if someone can come up with a diy version of a wheel balancer. has anyone got a bought balancer that can give us insight into how it does the job? could we use the wheel axle rod as part of a diy version?
Old 08-08-11, 08:10 PM   #7
ABBA do one, but you'd need to be doing a lot to justify the cost.
However it doesn't look too difficult to make something similar
http://www.abbastands.co.uk/product_details.asp?id=14
Old 08-08-11, 08:25 PM   #8
wheel balancer is basically 2 cones a rod and some tiny low friction bearings. i have one and don't use it as i have found something else which works.
Old 09-08-11, 08:56 AM   #9
Set of axle stands and a socket extension through the bearings, works fine.
Old 10-08-11, 01:45 AM   #10
Lozzo
So have I, it's called an electronic static and dynamic wheel balancing machine. Never could get it right the old way.
Balancing spots on new bike tyres. Where to they go in relation to the valve? monkey Bikes - Talk & Issues 9 24-02-08 12:39 AM
Carb balancing by ear? ikb SV Talk, Tuning & Tweaking 16 31-01-08 12:28 PM
Moron sold a bike after I'd agreed to buy the wheels monkey Bikes - Talk & Issues 20 20-10-07 01:23 PM
Think Bike - Do you when you're on 4 wheels? kciN Bikes - Talk & Issues 23 26-04-06 09:44 AM
Bike mods - why not lighter wheels? jump SV Talk, Tuning & Tweaking 23 11-07-05 02:11 PM
