Old 09-08-11, 01:01 PM   #1
radicalry00
Default Battery drainage - please help me sort it once and for all!
Right, my SV has been having some battery issues lately. After a week or so of not being used the battery is totally dead and it will not start.
I have done voltage tests over the battery to check if it's charging and here are the results:
Idle / Lights off: ~14.28v
5k RPM / Lights off: ~13.96v
Idle / Lights on: ~13.66v
5k RPM / Lights on: ~13.00v
I'm guessing that the battery should be charging at over 14v when at 5k RPM even with the lights on?
I'm also guessing there is some sort of current leak when the bike is not being used as the bike can discharge a full battery in about 2 weeks. May sound like a stupid question but what setting should I put my multimeter on for testing for current loss? I'm garbage when it comes to electrics I know!
P.S the bike has a Datatool alarm fitted. Could this be causing a major current drain?
Old 09-08-11, 01:16 PM   #2
radicalry00
Default Re: Battery drainage - please help me sort it once and for all!
Also, battery and regulator were both replaced about 12 months ago.
Old 09-08-11, 05:53 PM   #3
NedSVS
Did you recharge the battery before testing the voltages? The output should be checked with a fully charged battery. To check the leakage current just disconect one of the battery terminals and use your multimeter on the DC amps setting. I would guess it should only be drawing milliamps. If you haven't got the information on how much the alarm should draw, look up the manufacturer on the internet and ask them. If the battery has been left flat too many times then its performance will have suffered - even though it is only about 1 year old.
Old 09-08-11, 06:10 PM   #4
Winder
Winder's Avatar
Alarms are a battery zapper!
Old 09-08-11, 06:24 PM   #5
fizzwheel
fizzwheel's Avatar
I'd look at the datatool as being the culprit before I started looking elsewhere TBH.
Mind you I would have thought it would last longer than a week before being flat enough that you can't start the bike.
Old 09-08-11, 08:59 PM   #6
If your battery is even slightly better than a paperweight at supplying current a Datatool won't flatten it in a week.
Old 11-08-11, 07:30 AM   #7
Geese
TAke off the neg - battery lead
Make sure the bike if off.
set multimeter to amps
One end on the battery and one end on the lead using the meter to bridge the two.
Read the numbers.
Or google it in case i've got a step wrong.
Can a loose battery terminal prevent the battery from charging while being able to crank the engine? maxinc Bikes - Talk & Issues 5 22-07-11 02:59 PM
Blocked tank drainage Smudge Bikes - Talk & Issues 0 20-10-10 05:35 PM
Fuel Cap Drainage Issue Drew Carey Bikes - Talk & Issues 5 13-04-10 10:00 PM
"Small" drainage pipes causing corrosion on fairing Springbokki SV Talk, Tuning & Tweaking 8 11-12-09 06:12 AM
