Old 21-09-11, 04:19 PM   #1
enzoalex
Default Restricted SV shift points, and constantly changing temp
Hi guys two questions for you.
First one - To those of you on a restricted SV, I think this will only be relevant to the ones restricted by ECU, when you are trying to go fast, or overtake something, at what revs do you normally shift at.
I'm wondering because I'm sure my bike feels faster in the lower revs than the higher revs, so I don't normally do more than 6 or 7k.
I think this might be because the bike is restricted to 33hp, and hp = torque x revs so the higher the revs, the less torque you have.
Second one - I noticed my temperature today was jumping all over the place every two or three seconds it would jump by a few degrees as in 89, 87, 84, 81, 80, 81, 86, 90 And then back down again. Is this normal?
Thanks.
Old 21-09-11, 04:49 PM   #2
chris8886
chris8886's Avatar
Default Re: Restricted SV shift points, and constantly changing temp
i've no idea about the temperature thing cos i've got a curvy n therefore don't have a digital temperature gauge. as for when to shift i never looked at the rev counter to see when to shift up, i did it by noise and feel. basically, if i was really going for it i'd give the full beans and wait till i could feel the bike start to loose breath as it were and would then change up without the clutch to try and keep things speedy.
AR08 to AR13-QUALITY!
Old 21-09-11, 05:05 PM   #3
DJ123
DJ123's Avatar
it would start to lose breath the higher up the revs due to the way the restriction works. Yeah thats fine, the temp changes rapidly whilst you're riding, in traffic etc etc. it generally averages around the late 80's
BMW F800ST
Old 22-09-11, 10:34 AM   #4
SoulKiss
SoulKiss's Avatar
Originally Posted by Reecey91 View Post
My advice.. Remove the restricors.. Don't drive like one of these cockends and get pulled and you should be okay.
From past experience it will slowly kill / damage your bike.. Maybe it could do with a full power blast every now and then to stop all the **** choking up your bike.
Just a suggestion =)
My advice - stop being a moron and advising people to break the law for a reason thats a load of rubbish
Old 22-09-11, 12:24 PM   #5
enzoalex
Restriction comes off in March anyway, and I'm off to uni so I won't be using it much till then.
Old 02-10-11, 04:06 PM   #6
Felix_
Few days late, but heres my input ;p.
I change gear at around 8k rpm since the restrictor drops the power off at 8,500.
Also I think that's normal with the temp, mine does it all the time. I expect it's were you're doing different speeds, going into a cooler part of the road e.g under tree's.
Old 02-10-11, 05:27 PM   #7
enzoalex
8k, interesting.
I thought the restrictor kicks in at 5k. as that's where the bike makes 33hp:
My bike feels pretty dead at 8k.
As for the temperature, this was at the same speed, in the same gear, on a flat. Could have been the trees affecting it. I've not noticed it doing it before, and I haven't been anywhere on my bike since then.
I'll have to check it next time I ride it, Which will be 16th October - Hogging the Bridge.
Anyone else coming? I went last year on my 125 and it was really good, not to mention its for a good cause.
Old 02-10-11, 05:40 PM   #8
Felix_
Is your SV a curvy model or pointy?
Flat out in top gear on my pointy is 8.5k rpm @ 104mph (Indicated). It won't pull past 8,500 rpm in 4th, 5th or 6th but will in the lower three gears. I'm assuming the power drops out because that's what I got told when it was put on. It certainly feels like the power drops off at that RPM range though.
EDIT: Also, my temp changed all the time. Only really stays at a constant temp if I'm on a dual carriageway/motorway.
Old 02-10-11, 05:43 PM   #9
enzoalex
It's a pointy. I just found that dyno map on google images.
I think the reason you're not getting past 8.5k in top is because the air resistance at that speed is equal to the force of the engine. Meaning you can't accelerate any more.
Whereas in the lower gears, you aren't travelling as fast, and so air resistance is less and you can keep accelerating past 8.5k.
Old 02-10-11, 05:44 PM   #10
Jayneflakes
Jayneflakes's Avatar
My K3 is restricted, this means I change gear more often and am generally in a lower gear when accelerating to join the motorway. Gear shifts are higher in the rev range due to lower gear. Once at speed I will changing from sixth to fifth and even occasionally into forth when I need to pass a slow moving truck on the motorway, passing while going up hill is hard work at times. Very rarely do I need to worry about high revs when riding about town, thirty three brake is more than enough for every day riding around here.
My temp range for the K3 varies with riding type and weather conditions. As long as it is not heading past the hundred mark by too much, do you need to worry?
Jayne you're a Pussy Magnet
Oil Temp, Engine Temp and Rad Temp Owenski Bikes - Talk & Issues 0 30-06-11 09:36 AM
Gear Shift Rod bent - Gear Changing problem Thaleshwar SV Talk, Tuning & Tweaking 13 05-06-10 06:28 PM
Cooling fans constantly on stuartgallafant SV Talk, Tuning & Tweaking 7 12-10-09 03:50 PM
Shift-I Shift Light phizog SV Talk, Tuning & Tweaking 11 09-07-08 12:18 AM
Ideal Shift Points madEG SV Talk, Tuning & Tweaking 17 21-12-04 10:05 AM
