Old 17-10-11, 02:57 PM   #1
cmjhs
Default bypassing clutch switch and side stand on 2010 model?
converting my bike into race spec and doing away with lefthand switch gear what wires and is it ok to bypass the clutch switch and also the side stand switch?
thanks
Old 17-10-11, 07:41 PM   #2
Default Re: bypassing clutch switch and side stand on 2010 model?
Don't bypass the clutch switch on an FI bike.
Old 18-10-11, 08:41 AM   #3
SV650Racer
Bypassing the clutch switch puts the bike into a neutral gear ignition map so leave as it is.
Old 18-10-11, 08:10 PM   #4
Mark_h
Mark_h's Avatar
I've intermittently had my clutch switch looped out. What is the symptom of the neutral map as I don't think I ever noticed anything or does it not apply to a K3 thou?
Minister for Sustainability
Old 18-10-11, 08:29 PM   #5
Drumming_Animal
Never seemed to notice anything from my K4 and I've bypassed my clutch switch.
Unless I was to notice a difference if I was to un-bypass it.
Old 19-10-11, 07:16 AM   #6
MJC-DEV
MJC-DEV's Avatar
Experts can correct me but on the circuit diagrams I have seen, there is no connection between clutch switch and ECU on bikes before the K8. So I think this neutral map business only applies to k8 and later. Before that, it's only in series with the start/neutral/side stand switches
MJC-DEV is offline   Reply With Quote
Old 19-10-11, 08:10 AM   #7
SV650Racer
Its on all FI bikes. The SV will run a neutral ignition map, meaning the ignition is retarded slightly. On the SV there is a minimal power/acceleration loss. On the GSXR600 the bike will make approx 80bhp!!. On the GSXR1000 it will loose approx 1500rpm off the revs. The SV1000 is the same as the SV650.
We spent ages with tech guys from Suzuki with info from Japan on how to bypass the switch succesfully and no solution was found, well not one that made disconnecting the switch worthwhile, pulling the clutch in to start the bike was simpler put it that way!!
Old 19-10-11, 09:09 AM   #8
ryangarside
does it retard the ignition on the carbed models aswell by any chance? just a thought, not fully sure how the cdi ignition works
Clutch switch bypassing - the real truth? Reeder SV Talk, Tuning & Tweaking 12 28-07-10 06:33 AM
Bypassing clutch switch permanently. darkdreamsgal SV Talk, Tuning & Tweaking 16 20-06-10 09:41 AM
Side stand cut out switch cammy SV Talk, Tuning & Tweaking 3 25-07-09 02:33 PM
Bypassing The Side Stand Switch squirrel_hunter SV Talk, Tuning & Tweaking 10 23-06-07 09:50 PM
Side stand switch jonhunt SV Talk, Tuning & Tweaking 2 15-01-07 11:37 AM
