Old 04-01-12, 12:44 PM   #1
AkiraSV
Default Rear brake leak?
My SV is currently being stored in a family members garage over winter (I don't have a garage at home) and hasn't been used since late October. The other day I went to check on the bike, got her out, started her up, gave the clutch and front brake a few grabs, both were fine. Then I gave the rear brake some pressure and the lever went down for miles, hardly any pressure at all.
I had a look and there was a neat line of brake fluid that had ran down the brake hose to it's lowest point then dripped down the swing arm. The leak appears to be coming from the bottom of the reservoir from what I can tell (not so much of an educated eye..). Any idea on what could be causing this and how to fix it?
Before this the brake fluid was at the 'max' line, but it had gone down 8-10mm from what I can remember; wiped all the brake fluid up and wrapped a cloth around the hosing for now to absorb any more leakage.
Hope everyone here had a good new year.
Old 04-01-12, 01:01 PM   #2
TamSV
TamSV's Avatar
Default Re: Rear brake leak?
Check the banjo connection at the master cylinder (footpeg end) is secure, and the hose between the reservoir and master cylinder is securely attached at both ends.
Also carefully check both the hoses for any splits or damage.
Old 04-01-12, 08:08 PM   #3
SV Mad
Had similar on mine but back in the summer. Used it as a sign and got a HELL brake line, new hose from reservoir to master cylinder and all new hose clamps. Works a treat and not lost a drop since.
Old 04-01-12, 09:41 PM   #4
AkiraSV
Used it as a sign of?
TamSV, will check those when I'm next there (next weekend from the looks of things, sigh...)
Old 04-01-12, 10:43 PM   #5
muzikill
muzikill's Avatar
Whats akira is saying is 'its a sign to replace/renew something'
Look across at at the gubbins of it all on the back of the heel plate from the other side of the swing arm. You should see where the leaks coming from. Report back here.
K3 perhaps? Im in the process of replacing the hoses with braided ones.
Guess which hose end was the front caliper & the rear caliper.....
Old 04-01-12, 11:16 PM   #6
AkiraSV
Ahh I get ya! And yep it's a K3.
Will try that then, and I'll get some pics if it isn't immediately obvious. Been pricing up some rear hoses, £27 for a HEL rear line isn't too bad at all if it turns out to be a case of replacing that. We'll see...
Thanks for the replies everyone.
Old 05-01-12, 05:50 PM   #7
SV Mad
Tell HELL when you order you're a member of the SV.org and ask for 20% off.
Old 05-01-12, 08:17 PM   #8
AkiraSV
Serious??
Old 05-01-12, 08:31 PM   #9
SVMAT
You can pick up braided Hel/goodridge kits quite cheap on ebay, the kit on my sv is actually for a gsxr, i think as long as the lines are long enough the kits are prety interchangable within reason.
Old 06-01-12, 08:33 PM   #10
SV Mad
Serious??
Serious. Just say your a member and please can I have 20% off and the geezer will say 'no probs mate'.
brake fluid leak advice please jimc SV Talk, Tuning & Tweaking 4 27-02-11 03:09 PM
Curvy brake lever & rear brake pedal Old Git Stuff Wanted 1 09-01-10 11:00 AM
footpeg bracket, rear rear brake lever, clip on. plowsie Stuff Wanted 3 05-08-09 03:44 PM
Rear shock remote resevoir leak - help! Ginjaian SV Talk, Tuning & Tweaking 4 26-03-09 06:51 PM
Cleaning all around the rear wheel / swingarm / rear brake caliper Camel SV Talk, Tuning & Tweaking 12 28-04-08 02:00 PM
