Old 29-01-12, 12:21 AM   #1
suzukigt380paul
Default Curvy v Bandit v Pointy trackday at snetterton
ok so a new thread about this here challenge ive talked myself in to,and does any one know just how loud 102 db's is because my b6 aint got a baffle never has,the not for road use has been polised out of the end can,not by me i might add
Old 29-01-12, 01:26 PM   #2
kaivalagi
Default Re: Curvy v Bandit v Pointy trackday at snetterton
Do you have an android phone / iphone? Get a free app to measure the DB, that'll be close enough. I think most baffle-less cans would exceed 102db, but not necessarily all.
Mark
Triumph and Suzuki owner
Old 29-01-12, 01:59 PM   #3
I've got a Db killer you can fit to reduce the noise level
Old 29-01-12, 08:29 PM   #4
suzukigt380paul
are all the Db killer/baffle the same size,never even thought of putting one in as the end can never ever had one so never had a hole for screw or groove for circlip to hold it in place,plus the fact it will likely knock 5+ hp off the output
Old 29-01-12, 08:47 PM   #5
Dave20046
Dave20046's Avatar
Not sure about 5hp but it did make my curvy run like a bag of ****. If you tune the rest of it to suit it should be fine*. I used a bikeit universal one, drill a hole and screw a bolt ('bolt a bolt?') easy.
* but that's a fair old effort to say yours may be okay. if it helps you work it out at all I had a non road legal ART can (never had a baffle) which had been DIY stubbied which measured a bit over 103db. I would guess a unmolested exhaust would fair better.
Old 29-01-12, 09:05 PM   #6
suzukigt380paul
the end can on mine i beleive is a micron "not for road" use,and has a alloy case if this makes any differance,and this has been on the bike ever since i bought it and it runs very well with this set up,i allso have a b12 k3 with a scorpion end can with a baffle this runs like sh*t if you take the baffle out
Old 29-01-12, 09:32 PM   #7
Dave20046
Dave20046's Avatar
binky has a micron (strainless with the blue burnt {dis}colouring)which has been stubbied (possibly more than once!) and is probably the loudest exhaust I've heard (bar harley davidsons) which measured 104db at cadwell IIRC. If only we knew how much difference stubbying made! micron's a very common aftermarket, someone will have one and be able to tell you.
Old 29-01-12, 10:39 PM   #8
Think so, I fitted a DB killer to a Scorpion can, which didn't have a baffle or any way of securing it.
Just drilled a hole in the underside of the tail pipe that came out out of the can
So as Red Herring said in page 6 of the other thread, the excuses have started already
http://forums.sv650.org/showthread.php?t=174591&page=6
Don't even think about sloting your 1200 engine in the 600 frame, or shoehorning your Blade engine in the 600 frame, nor painting you 1200 bandit in the same colour as the 600, we will know
Old 28-03-12, 08:24 PM   #9
BUMP
Just when you thought I'd forgotten about this
So a couple of dates I can make, there are others with ClubMSV, but these are the ones I can do.
April 16th - novice only track day
http://www.clubmsv.com/bike-home/eve...productid=1239
May 3rd
http://www.clubmsv.com/bike-home/eve...productid=1314
June 4th
http://www.clubmsv.com/bike-home/eve...productid=1302
May well do the April & June dates
Who's up for it?
Old 28-03-12, 09:25 PM   #10
svrich
Maybe the June one if it's in the half term. All the others are term time
Recent OMCC Snetterton Trackday Sept 28/29 stormingjoe Photos 1 05-10-11 08:02 PM
Do I change my brand new pointy for a Bandit? Baz Bikes - Talk & Issues 35 23-03-09 12:38 PM
Trackday - Snetterton - Sun 8th April weazelz Track Days 0 17-04-07 10:11 AM
Trackday - Snetterton - Sun 8th April weazelz Bikes - Talk & Issues 25 09-04-07 09:10 PM
Snetterton trackday was ace! A-jay Bikes - Talk & Issues 0 24-06-06 01:57 PM
