Old 06-03-12, 01:21 PM   #1
Macpauley
Default 115 miles 'til fuel light.
115 miles till the flashing light!
Old 06-03-12, 01:27 PM   #2
manicjazz
Default Re: That's a new one....
Me too!! Not happy bob.
Had the plunger sorted a tank ago too so was expecting more not less this time.
Have you put free flow air filter in or changed exhaust??
Old 06-03-12, 01:46 PM   #3
Macpauley
No I've changed nothing, I average about 130 - 140ish but this week it's way down...
Time for a service?
Old 06-03-12, 04:49 PM   #4
EssexDave
My curvy is doing about that - 110 to light.
Going to check the jet size. It does have a lovely sounding Remus can on - will need to have a good look over.
Old 06-03-12, 07:34 PM   #5
rictus01
rictus01's Avatar
Default Re: 115 miles 'til fuel light.
whilst the setup and service of the bike have an effect on consumption*, the journey type as well as throttle use tend to have more.
On a recent trip in ice and snow (necessitating smooth throttle application) it raise mileage per tank to close to 140, on a bike that under normal use returns 100.
* also you have the "my bike does 145 mph" effect with consumption exaggeration as well......
Cheers Mark.
Old 06-03-12, 07:37 PM   #6
yup as rictus points out it's to do with your right hand and condition of bike. for instance a loose, worn or badly adjusted chain will eat at your petrol consumption.
Old 07-03-12, 09:45 AM   #7
Macpauley
Hmmm, I haven't been particularly heavy handed this week or had any unusual journeys.
I have been thinking of new chain, sprockets & service. But I'll also be needing some new hoops soon & was putting the rest off so I can do it all at once.... But I'll check the chain tension tonight.
How much difference can a can make to fuel usage? As the bike came with a renegade can on it, should I be checking the carbs?
Old 07-03-12, 10:16 AM   #8
every little helps. depending on the mileage and when a service was last done.
air filter
oil and filter
spark plugs
carb balance
brakes
tyre pressures
you say 115miles but how many litres are you putting in for the 115miles?
keep your petrol receipts and write the mileage down on the back. you can then work out your MPL/MPG. i do this as it gives an indication if there is something wrong if my MPG starts to go down.
Old 07-03-12, 10:19 AM   #9
takracing
1. Standard Maintenance (Chain light lube & tension, check chain sprocket condition / age, clean bike, check brakes not binding, check wheel bearings are OK)
2. Tyre pressures and condition (a rear tyre with a flat middle has much more rolling resistance than a new nicely rounded tyre).
3. Service
4. Carb Balance
5. Petrol (Some cheap stuff is propper crud)
6. Less right wrist
My curvy has done about 4500 miles from new and I recently got 145 miles from fill up (Shell) to light on a reasonable run with some quick riding at points
Jim
Old 07-03-12, 10:23 AM   #10
Nobbylad
Nobbylad's Avatar
133 yesterday from brimmed to flashing.
Pretty sure I got more when I used Shell Advance the time before.
Pointy Fuel Light- Not another how many miles thread Vergey SV Talk, Tuning & Tweaking 3 06-08-11 01:01 PM
OMG! 143 miles until fuel light 53mpg! I'm_a_Newbie SV Talk, Tuning & Tweaking 22 26-06-08 12:06 PM
125 Miles Until Fuel Light, Yippee I'm_a_Newbie SV Talk, Tuning & Tweaking 13 14-05-08 12:03 PM
fuel light flashing how many miles till it runs out jans1971 Bikes - Talk & Issues 29 10-10-07 09:47 PM
180 miles and no fuel light... Tiger 55 Bikes - Talk & Issues 21 09-07-07 06:25 PM
