Old 14-04-12, 07:58 AM   #1
dazzaboy
Default Performance filter do anything?
I have a curvy with a beowulf exhaust, everything else is standard e.g carb jets. Will a filter do much or will it mess it up more if i don't rejet aswell
Old 14-04-12, 08:07 AM   #2
rictus01
rictus01's Avatar
Default Re: Performance filter do anything?
depends on which "performance" filter you mean, for example K&N do a direct replacement for the standard one, no performance gain, but cleanable; so you never need to buy another filter again, just having a slipon can, you don't need to change anything else, but BMC make 3 different air filters for the Curvy, one a road replacement, another higher performance one and the race RS version, the last two would require other changes to work correctly (example you fit an raceRS with you current setup and it won't rev past 6k or so).
So really your question doesn't have enough information to make any answer complete.
Cheers Mark.
Old 14-04-12, 08:37 AM   #3
MJC-DEV
MJC-DEV's Avatar
Generally you are better off using the OEM filter for best filtering and flow rate unless you are racing or really want a cleanable type.
2006 SK6, wavy discs, 8.5N K-Tech springs, Debrix Emulators, Nitron Shock, Silkolene RSF Pro 10W, Eastern Beaver H4 Dual Headlight Relay Kit, Avon Storm Ultra 2 tyres, Ebay billet brake/clutch levers
MJC-DEV is offline   Reply With Quote
Old 14-04-12, 09:26 AM   #4
rictus01
rictus01's Avatar
I'd have to disagree, economy is a major fator for me, doing 8-10 services a year means I clean
my K&N twice a year, at roughly twice the cost of OEM, it paid for itself in a very short tim
Old 14-04-12, 10:53 AM   #5
AmigaNut
Surley thats not 8-10 on the same bike, if so how many miles do you do?
AmigaNut
Old 14-04-12, 11:07 AM   #6
rictus01
rictus01's Avatar
shared between a couple of bikes, but normally around 40k a year, you tend to find the most economic way of doing things.
Cheers Mark.
Old 14-04-12, 11:23 AM   #7
MJC-DEV
MJC-DEV's Avatar
Sure, as I said if you really want a cleanable filter - get one. I do about 4K a year so the OEM filter lasts around 3 years. Since they filter better than K&N, they are the best solution for me.
But, back to the original post +1,
"So really your question doesn't have enough information to make any answer complete"
this is absolutely true!
Old 14-04-12, 02:20 PM   #8
dazzaboy
i don'tdomany miles so the standard one will probably work out cheapest for me
Old 14-04-12, 03:34 PM   #9
sicknote
I recently put a K&N air filter in my 1st gen SV650, motor is stock apart from Yoshimura silencer.
It messed up the carburation, too weak. popping and failure to rev on start up till a bit warm then
pulls cleanly, sounds good, but drives like it is starving of fuel,though things improve as the engine warms.
My stock filter is absolutely filthy, ( you can see down the plastic tube ) & with it in, bike feels like it is running rich ,but the top end feels flat.
The K&N filter has no tube down the middle which must make air flow much greater one would have thought.
Certainly no good putting it in without a rejet on my SV
Air Filter & Oil Filter from TL1000R fit SV650? AkiraSV SV Talk, Tuning & Tweaking 3 04-08-11 05:19 PM
Spark Plugs, oil filter, Air Filter....Curvy 21QUEST For Sale - SV's and SV related items 2 14-01-10 10:04 PM
Pipercross performance air Filter danf1234 For Sale - SV's and SV related items 6 25-06-07 07:45 PM
Cheap performance filter? Blue_SV650S SV Talk, Tuning & Tweaking 6 24-06-07 10:14 PM
Performance Air filter help and reccomendations sv650s 1999 csimmo SV Talk, Tuning & Tweaking 8 28-01-05 01:04 PM
