Old 14-04-12, 12:49 PM   #1
Littlepeahead
Littlepeahead's Avatar
Default Superglue - help!
No laughing, but I just managed to superglue my thumb and finger together. I've managed to cut them apart but my hands are covered in glue and so is a glass table thanks to a faulty lid.
Any ideas how to remove it?
Old 14-04-12, 12:54 PM   #2
AZZ3R
Default Re: Superglue - help!
I've been told it's superglue, it will turn it back asif it hasn't set. But, I'm sure someone knows a propper cleaning agent to get it up with.
Old 14-04-12, 12:56 PM   #3
jambo
jambo's Avatar
Hot soapy water, scrubbing and patience unfortunately is about as good as you're going to get.
Old 14-04-12, 01:02 PM   #4
Littlepeahead
It's ruined my manicure. And the thing it was supposed to stick - small curtain rod hook to conservatory frame - has just fallen down again.
Old 14-04-12, 01:26 PM   #5
SoulKiss
SoulKiss's Avatar
Well as the manicure is ruined anyway... Nail Varnish Remover
Originally Posted by wikipedia
Solvents and debonders
Acetone, commonly found in nail polish remover, is a widely available solvent capable of softening cured cyanoacrylate.[19] Other solvents include Nitromethane, Dimethyl sulfoxide, and Methylene chloride, although the latter two of these solvents are toxic.[20] Gamma-butyrolactone may also be used to remove cured cyanoacrylate.[21] Commercial debonders are also available.[22]
Old 14-04-12, 01:32 PM   #6
wyrdness
+1. Nail varnish remover should shift it.
Old 14-04-12, 01:42 PM   #7
Small Clanger
Slightly off-topic but I've just read "The Complete History of Glue"
I simply could'nt put it down.
Old 14-04-12, 01:51 PM   #8
Noddy
If you are using nail varnish remover to shift it you need proper acetone type stuff, the newer synthetic type remover doesn't work.
Old 14-04-12, 01:53 PM   #9
Suchy
Surely this should be a sticky thread
Old 14-04-12, 02:04 PM   #10
SuzukiNess
super when it works where it supposed too.. horrid when it everywhere else..
Superglue in garage door lock Geodude Idle Banter 20 31-07-11 08:39 PM
Superglue! Kate Moss Idle Banter 41 25-04-09 10:01 AM
How do you break superglue? Stu Bikes - Talk & Issues 32 13-07-07 05:54 PM
will superglue melt rubber? hovis Idle Banter 21 29-04-07 07:49 PM
