Old 01-05-12, 07:00 PM   #1
Bordtea
Default Moving radiator forward?
Hi all
Trying to change spark plugs on my curvy and have to move the radiator forward to get access to the front spark plug. I've taken the bottom bolt out of the radiator as it says to do in haynes but the radiator won't budge. Can't see anywhere else that its connected to though :/ Is it a case of just force it or am I missing something?
Old 01-05-12, 07:03 PM   #2
Default Re: Moving radiator forward
Yep, doesn't move far, just wedge it open with a suitably sized piece of wood
Hoses flex a bit more if they're warm, so do it a little bit after a ride, but not so that the engine is hot that you burn yourself
Old 01-05-12, 07:07 PM   #3
dyzio
dyzio's Avatar
My memory is vague, but have you taken the fairing bolts out as well? If I'm right the side fairing are held by the radiator.
Take the horn off as well, you might damage the rad against it.
Old 01-05-12, 07:08 PM   #4
Bordtea
No haven't removed the fairing, that could be why.
Horn's off, not that the rad could be any more damaged!
Old 01-05-12, 07:13 PM   #5
dyzio
dyzio's Avatar
You don't need to remove it completely.
Undo the side and top bolts on the side fairing, it's pushed into a rubber holder in the radiator as well. Pull it out gently.
Hope I'm making some sort of sense
Old 01-05-12, 07:15 PM   #6
The fairing sidepanels are connected by stubs into rubber bungs on the radiator.
Old 01-05-12, 07:29 PM   #7
Bordtea
Default Re: Moving radiator forward?
Cheers fellas, will go remove them now
Old 01-05-12, 08:16 PM   #8
Still won't help that much, unless I'd forgotten to do what Sid said, the last time I changed the front plug
Old 01-05-12, 08:37 PM   #9
Bordtea
Right got it far enough forward to get the old spark plug out (just)... never realised how bloody awkward it was to do, dont plan on doing this again for a while -__-
Half way there, now to get new ones back in...
Old 01-05-12, 08:43 PM   #10
Bordtea
Next problem is that the spark plug spanner doesnt bloody fit the new spark plugs properly, so not sure if im gonna be able to tighten sufficiently :/
as much as i am looking forward too davepreston Idle Banter 18 20-01-10 12:02 PM
Moving forward with the clutch in. 5hort5 SV Talk, Tuning & Tweaking 9 29-11-09 02:31 PM
Looking forward... ooger Idle Banter 17 08-10-09 11:01 AM
Trouble swinging radiator forward! sam anon SV Talk, Tuning & Tweaking 16 09-05-08 08:38 AM
is rear caliper 'floating'?? moving axle forward... branny SV Talk, Tuning & Tweaking 4 27-02-06 11:01 AM
