Old 28-05-12, 02:30 PM   #1
speedyctr
speedyctr's Avatar
Default Reg/Rec CBR unit OK?
I booked b&b in Wales Friday night for Saturday, looking forward to going on the bike. Come sat morning bike didn't start so went in the car instead Hope to make up for it this weekend!
Done a quick test but going to double check everything toinght with multimeter but can anyone please confirm that this is a good replacement - after searching I think this is the one most people seem to suggest. http://www.ebay.co.uk/itm/New-Rectif...item2eb8b67b3c
Thanks.
SV650S K3 Fuel oval exhaust, tail tidy, seat cowl, smoked double bubble w/pro bolts, clear indi's, mirror extendas, scottoiler, hel stainless brake cable, evotech crash protectors.
speedyctr is offline   Reply With Quote
Old 28-05-12, 10:30 PM   #2
speedyctr
speedyctr's Avatar
Default Re: Reg/Rec CBR unit OK?
http://www.ebay.co.uk/itm/suzuki-gsx...item3f18121cf1
Or this one? Looks the same to me. The CBR one isn't 2007+ so thats a no no i think.
Old 30-05-12, 06:30 PM   #3
speedyctr
speedyctr's Avatar
Gsxr reg rec was delivered today. It's connectors are slightly different. Is it ok to take them off and swap em over?
Old 30-05-12, 07:50 PM   #4
speedyctr
speedyctr's Avatar
Well swapped them over although should buy some new spades as they weren't exactly the same. Battery has been charged so bike did start but reading across the terminals was 11.5 when idle and 11.5 at 3k rpm. Something not quite right there
Turning into a bit of a commentary this but at least I can retrace my steps!
Old 30-05-12, 08:38 PM   #5
Jackie_Black
I have a feeling CBR reg/recs may have been discussed once or twice on here, do a quick search. Should help you.
Old 30-05-12, 08:41 PM   #6
speedyctr
speedyctr's Avatar
I have but not dumbed down enough for me trial n error thrown in with the info I found and learning along the way.
Old 30-05-12, 08:47 PM   #7
Jackie_Black
I seem to remember a while ago there was huge discussion/internet battle about reg/recs as far as i can remember there is nowt wrong with the standard one but the CBR one is a popular replacement.
Old 30-05-12, 10:05 PM   #8
Lucas
Here you go
http://forums.sv650.org/showthread.php?t=146148
HTH
Old 31-05-12, 07:21 AM   #9
Icanopit
There are very many threads regarding RegRec failure on bikes in particular Triumph Street Triples made 2007-10 failure rate VERY high, just changed mine. The following link makes very "good" reading and IS very adaptable and the SV is mentioned several times, may be of use.
http://www.triumphrat.net/speed-trip...r-upgrade.html
JOHN
Old 06-06-12, 08:46 AM   #10
speedyctr
speedyctr's Avatar
Default Re: Reg/Rec GSXR unit OK?
New battery in and the GSXR reg/rec on. Checked as much of the electrical system as possible. Checked the power from alternator, checked the voltage at stator, done diagnosis as the electrosport chart but still getting no charge! There was a 0.08a drain from the fuel system (stopped when fuse removed) but from a search over on svrider this seems normal. It must be a loose connection somewhere i think.
More info....
The day before it wouldn't start I adjusted the clutch and rear brake light switch. Could i have disturbed some crucial wiring in the process??
Another possible clue, I rode it yesterday with fully charged battery in hoping a 20min ride may produce some charge, I had a full tank but fuel light came on. Any ideas? I am flummoxed!!
Car Head unit, Owenski Idle Banter 3 03-09-10 11:43 AM
Flasher Unit adoh30 Bikes - Talk & Issues 0 05-08-08 06:10 PM
Reg/Rec unit - anything! yorkie_chris Stuff Wanted 13 07-07-08 11:06 AM
HID unit jonhunt SV Talk, Tuning & Tweaking 3 03-05-06 10:10 AM
Flasher unit. BURNER SV Talk, Tuning & Tweaking 2 24-01-05 07:45 PM
