Old 01-06-12, 10:45 AM   #1
Default Why?
Why would you stick a TL motor in a 916?
http://www.ebay.co.uk/itm/Ducati-916...3#ht_783wt_965
Old 01-06-12, 10:49 AM   #2
timwilky
timwilky's Avatar
Default Re: Why?
The explanation tells you why, somebody had a rolling chassis so had the bright idea of dropping the tl lump in it. Better chassis than the tl in the first place.
Not Grumpy, opinionated.
Old 01-06-12, 10:51 AM   #3
joshwalker094
joshwalker094's Avatar
Default Re: Why?
I like it and as too your why? It had no engine so someone stuck the TL one in
RIP Reeder
JOSH WALKERRRRRRRRRRRR
Old 01-06-12, 11:40 AM   #4
Default Re: Why?
Why the hell not?
TL1000R is a brilliant engine which can be mental. The duc engines are horrible to work on and break a lot.
Old 01-06-12, 11:44 AM   #5
jambo
jambo's Avatar
Default Re: Why?
The entire process is justified by the following scenario:
You ride up on your beautiful 916, pull the clutch in, and no one thinks you've got a set of spanners loose in the crank cases
Jambo
Old 01-06-12, 11:53 AM   #6
Default Re: Why?
Jambo
^^^^This
However I am biased in the opinion that any TL motor in an Italian, well handling suit, is a good thing
Old 01-06-12, 01:32 PM   #7
Default Re: Why?
Why the hell not?
Fair point, which I will concede
We've got the SB8 for that tho
To quote a punter in my local dealers:
"Owning a ducati is like making love to a beautiful woman"
I'll let you all finish that statement off
Jambo, its a skeleton w**king, while rolling down hill in a steel bin
Old 01-06-12, 03:24 PM   #8
xXBADGERXx
Default Re: Why?
Expensive , High Maintenance and they don`t get wet too often ?
Old 01-06-12, 03:27 PM   #9
Default Re: Why?
Or you can get it wet but it'll cost you
Like a beautiful woman after 17 pints... that feeling of rolling over in the morning and seeing "AAHHHHRRRG" ... is when you need to service it.
Old 01-06-12, 03:28 PM   #10
xXBADGERXx
Default Re: Why?
I reckon most Ducati owners have burned more calories boasting about Sex than actually doing it
