Old 20-06-12, 11:49 AM   #1
HoL
Default Valve clearances with a twist
I have managed to muller the plug (item 20 on here) as it was well & truely lodged in place on the generator cover so I can't turn the engine to do the valve clearances. I know the viewing window to see what position the engines in is built into the generator case too but is it possible to do the clearances by taking the whole generator cover off?
Since they only need doing every 15k then although it's a faff it'll save having to replace it.
I've got a naked K2 if it makes a difference
Old 20-06-12, 11:59 AM   #2
johnnyrod
johnnyrod's Avatar
Default Re: Valve clearances with a twist
Put it in top gear and sue the back wheel to turn the engine.
Old 20-06-12, 12:02 PM   #3
Nobbylad
Nobbylad's Avatar
You should be able to turn it with the plugs in I think.
Old 20-06-12, 12:18 PM   #4
take plugs out, put bike into second gear, take sprocket cover off and use the sprocket nut to turn engine.
Old 20-06-12, 12:27 PM   #5
Nobbylad
Nobbylad's Avatar
Ha ha...would help if I hadn't read the OP quickly on my phone lol
Old 20-06-12, 12:33 PM   #6
Owenski
Tip for removing that plug (provided you're buying a replacement).
Get your self an angle grinder disc spanner.
Should look something like this:
Drill 2 holes of suitable size and spacing to be able to get the spanner fitting well to your cover cap then tap the other end of the spanner with a hammer - will be slightly easier with the engine case warm through either running it or heating it manually.
Old 20-06-12, 12:49 PM   #7
HoL
Thanks chaps - I did think of that the other day then promptly forgot. Saves taking the cover off
Old 20-06-12, 01:00 PM   #8
Nobbylad
Nobbylad's Avatar
The plug is only light alloy/plastic anyway from what I remember. I snapped the thread off one on a K5 quite easily by overtightening it, so be careful when you do fit a replacement.
Old 20-06-12, 01:04 PM   #9
HoL
Nobbylad - you sound as bad as me! At least we're tryers eh?
Old 20-06-12, 01:35 PM   #10
Nobbylad
Nobbylad's Avatar
Yes indeed.
The good thing about doing jobs and fecking them up, is that the next time you come to do them, you know what can go wrong and therefore (usually) avoid them!
Valve Clearances stratman_001 SV Talk, Tuning & Tweaking 2 09-03-10 01:13 PM
Valve Clearances DanAbnormal Bikes - Talk & Issues 31 07-02-08 06:22 PM
Valve clearances yorkie_chris SV Talk, Tuning & Tweaking 41 28-09-07 06:46 AM
Valve Clearances - How 'Ard? Biker_Billy SV Talk, Tuning & Tweaking 19 19-06-07 11:04 AM
Doing the valve clearances... instigator SV Talk, Tuning & Tweaking 7 16-10-06 10:08 PM
