Old 01-07-12, 07:32 PM   #1
Sabarius
Default Clutch case stuck in place.
My clutch is causing problems so I want to check the springs and plates for wear.
This evening I drained my oil and coolant so was feeling a bit smug because I'm not so good at this kind of thing.
Then I removed the 14 bolts from the clutch cover but it won't budge. Have I missed something somewhere or is it just seized from age? In which case how do I free it up?
Bike is a 2004 K4 650S on about 25k miles.
Old 01-07-12, 08:08 PM   #2
Default Re: Crankcase wont come off
Give it a gentle tap with a soft headed hammer from different directions, its just stuck with age
Old 01-07-12, 08:15 PM   #3
Sabarius
Kk just been out again and tried that but no luck, it's still stuck fast. Can I use something like wd40?
Old 03-07-12, 07:05 AM   #4
tactcom7
Default Re: Clutch case stuck in place.
Did you keep all the oil and coolant? If so, stick it back in and run the engine till its warm amd try again.
Old 03-07-12, 01:16 PM   #5
TSM
The Sick Man
TSM's Avatar
have you removed all bolts? i think one of them goes though the waterpump as well.
Old 03-07-12, 02:12 PM   #6
dirtyred619
I had the same problem last year on a Suzuki GN125 and still dont know why it wouldn't come off. I know this doesn't help but at least you know its not just your cover that is stuck!
Old 03-07-12, 03:05 PM   #7
Owenski
Does the SV have dowels on the clutch cover? If it does you'll need to be pulling equally on all sides, tilt it at all and you'll get headache lockout.
Old 04-07-12, 01:49 PM   #8
Sabarius
Thanks for all the replies. I finally got it off, I found the metal tab underneath and hit it with a hammer then it wiggled lose with some effort.
Old 04-07-12, 01:59 PM   #9
rictus01
rictus01's Avatar
just a point to note for anyone reading this thread
rubber mallet or hide hammer is best, or if you must use a steel hammer use a bit of wood between the casing and the hammer, not that I've seening it a few years but you can easily break or damage the casing.
Cheers Mark.
Clutch dragging/stuck. Rossie SV Talk, Tuning & Tweaking 2 29-01-11 06:24 PM
clutch lever stuck? waxdaddy.co.uk SV Talk, Tuning & Tweaking 2 08-07-10 09:22 AM
Just in case Dicky Ticker The Essex Lounge 0 23-11-08 09:32 AM
Am i a sad case? svrash SV Talk, Tuning & Tweaking 6 07-08-06 06:12 PM
just in case you hadn't seen this.... CoolGirl Soho Massive 0 09-02-05 06:48 PM
