Old 08-07-12, 10:06 AM   #1
sv_rory
Default virus software
Does anybody know of a good virus software? My computer is playing up big time and theres so many different versions etc I have no idea whats best
Old 08-07-12, 10:09 AM   #2
Elliott
Kaspersky
Always on offer as well.
Old 08-07-12, 10:12 AM   #3
sv_rory
Default Re: virus software
I've seen that one advertised but not heard of any reveiws.
ive tried avg and that doesn't find anything wrong whren im pretty sure there is
Old 08-07-12, 10:15 AM   #4
slark01
Avast is free. I use it and have no problems.
Ste.
Old 08-07-12, 10:17 AM   #5
grimey121uk
If you have a virus infection, simply installing an anti virus program over the top wont usually fix/detect the issue. I would recommend removing the HDD and installing it in a cadie and using a separate computer to run a scan. Alternativly you could install and run a scan in safe mode.
Another usefull tool to run for free is Kaspersky TDS killer which hunts down root kits, a root kit in basic terms is a sophisticated virus which hides "in the background" within the system (http://support.kaspersky.com/faq/?qid=208283363)
Old 08-07-12, 10:21 AM   #6
sv_rory
Right ill have a go at that now thanks,
It's weird because the pc is running so slow and keeps freezing.
When you first turn it on it loads up then freezes, it will reset itself automatically then it works fine, although internet explorer freezes constantly
Old 08-07-12, 10:28 AM   #7
sv_rory
right i've dont that and it found 6 threats. I clicked delete and it then said to reboot the pc. I've done that and seems to have loaded fine, however it now says on load up no burning drive is found?
Old 08-07-12, 10:32 AM   #8
grimey121uk
Any chance of a screenshot?
Also, I would do a full virus scan in safe mode with a regular virus scan ans the TDS killer only looks at running processes so the infected files may still be present and re infect!
Basically I would run TDS killer in "normal mode", then on reboot go into safe mode and run tds killer followed by a full system scan (ms security essentials is free)
Old 08-07-12, 10:36 AM   #9
sv_rory
How do I reboot into safe mode mate?
Old 08-07-12, 10:37 AM   #10
grimey121uk
Tap the F8 key whilst Windows load and then select it from the menu
Reccommend Me Some Free Anti-Virus Software and Maybe Internet Security, You Know the Like :) Sally Idle Banter 32 11-11-09 12:40 PM
Get Free Really Good Anti Virus Software Here! Sally Idle Banter 61 05-03-09 05:33 PM
Virus ? Mr Toad Idle Banter 22 05-09-08 01:59 PM
How to remove virus? StreetHawk Idle Banter 5 28-08-08 03:07 PM
I have a virus Stig Idle Banter 4 10-11-07 10:00 AM
