Old 08-08-12, 12:16 PM   #1
Gaz.sv650
Gaz.sv650's Avatar
Default dyno jet power commander III
For a K6 650
Thanks
Gaz.sv650 is offline   Reply With Quote
Old 09-08-12, 04:16 PM   #2
phil24_7
Default Re: dyno jet power commander III
You thought about a Yoshi tune? Much cheaper and you wont get vastly different results on the SV.
Regards
Phil
Old 09-08-12, 04:44 PM   #3
MMN
Yoshi tune?
Old 09-08-12, 05:00 PM   #4
phil24_7
Yeah. You can get your current ECU re-programmed by a Yoshi box. It doesn't have the same amount of adjustments as a PCIII but on the SV650 the difference isn't massive.
Old 09-08-12, 05:27 PM   #5
Gaz.sv650
Gaz.sv650's Avatar
Thanks for the tip will have a look in to it is it the same concept still able to download maps and have it fine tuned on the dyno?
Old 09-08-12, 05:39 PM   #6
phil24_7
Nope, no maps. You take it to a place that can do the tuning, throw them £90 and they will tune it. The 2 main differences are that you don't need to buy a power commander and the tuning is considerably cheaper.
Once it's tuned, you don't need to change maps, not even on the PCIII. The generic maps for a PCIII will not be optimised for your specific machine anyway.
Regards
Phil
Dyno Jet Power Commander 650/650s 03-06 pilgrim_fgau For Sale - SV's and SV related items 8 07-02-12 09:55 PM
Power Commander, power increase? sephy666 SV Talk, Tuning & Tweaking 1 20-02-11 09:59 AM
Power Commander power graph print outs. JimPSV SV Talk, Tuning & Tweaking 19 27-11-06 09:39 AM
Dyno tune & Power Commander...if you ever... Shooter SV Talk, Tuning & Tweaking 4 16-10-04 08:57 PM
