Old 18-08-12, 08:53 PM   #1
Badeye
Default GSXR front end speedo drive questions.
So i have been thinking about doing the GSXR front end swap for sometime now but i wanna make sure eveything is spot on in my head before i start investing.
So the big problem i have been reading is the speedo. Is it possible to do the front end swap but use the SV1000 speedo? If so how do i fit an SV1000 speedo to a 650, if not, why not?
Si
Old 18-08-12, 09:04 PM   #2
Default Re: Question about speedo swaps
heheheeeee. my kit almost done
you have to drill/tap the sprocket shaft to use GSXR/SV1000 etc.etc speedo drive and the pulse don't work with later gen SV as it has 8
Old 18-08-12, 09:29 PM   #3
here is a rough (test piece) of what it will look like:
the finished items will look better as the disc will be made with recesses for the magnets.
Old 18-08-12, 09:36 PM   #4
Beetrootkiller
When I did my front end swap I had the speedo problem too...
I've got a K4 SVS and use a gear tooth sensor connected to the existing wiring and use 4 magnets in the recesses of the disc on the front. It gives an accurate reading and has been reliable for months now
Very pleased with the overall result
HTH
Old 18-08-12, 10:43 PM   #5
yup that works perfect but you have to keep buying OEM discs as most of the aftermarket ones have odd number of bobbins.
Old 19-08-12, 05:37 PM   #6
If you're careful you can put the pickup inside the front mudguard - by far the neatest solution.
Curvy Speedo Drive & Front Wheel Serdna Stuff Wanted 0 18-07-12 11:28 AM
Reversing front wheel - speedo drive? piey62 SV Talk, Tuning & Tweaking 3 16-06-12 12:25 PM
Hayabusa speedo issues - drive from front wheel? AirArmed Bikes - Talk & Issues 9 06-10-10 10:31 PM
GSXR front end speedo svdemon SV Talk, Tuning & Tweaking 0 30-09-09 03:59 PM
speedo problem w/ GSXR front end catchsomesv650 SV Talk, Tuning & Tweaking 4 19-02-09 08:46 PM
