Old 26-08-12, 08:22 PM   #1
Red ones
Red ones's Avatar
Default It might be on its way to the scrapyard
Yep. You read it right.
After 7 years and 86,000 miles it looks like my SV is on its way. MOT failure on 4 points including suspension linkage. The repair for a 7 yr old high mileage bike (following front suspension last year, and 2 tyres in the next few weeks) suggests it is time to throw the towel in and look for something else.
The OH doesn't like the idea of the sensible option for a replacement (2nd hand Pan European) or the low mileage F650GS. So I'm off to test ride a couple of NC700's tomorrow!!
Old 26-08-12, 08:23 PM   #2
DJ123
DJ123's Avatar
Default Re: It might be on its way to the scrapyard
What else did it fail on? i've jsut done the suspension linkage on mine
BMW F800ST
Old 26-08-12, 08:30 PM   #3
davepreston
if you're just looking pennies for it i'll have it off you
Old 26-08-12, 08:41 PM   #4
Pan Euro, one of the campers at Peel had the SV as a toy and the Pan as a hack
TBH put it on the Org you'll get something for it!
Old 26-08-12, 08:56 PM   #5
muzikill
muzikill's Avatar
Dont chuck it away noooooo....
Old 26-08-12, 09:04 PM   #6
Beetrootkiller
There's someone in the stuff wanted section after a project SV.
Why not head over see of you can't come to a deal?
Old 26-08-12, 09:13 PM   #7
widepants
widepants's Avatar
tight ****
widepants is offline   Reply With Quote
Old 26-08-12, 09:27 PM   #8
Red ones
Red ones's Avatar
I shall be holding out for some value - i need the deposit on the next one!!!
It'll be interesting to see how the NC700 feels - low revving (6,500 rpm) and low output (68 bhp) against the 11,000 rpm and 57bhp of the SV. 115mph seems a bit lower than the more usual 128 - 130 of the SV too
Old 27-08-12, 10:12 AM   #9
stewie
Stick it up in the for sale section, I'm sure someone will give you more than scrap value for it
Old 27-08-12, 11:54 AM   #10
Don't bin it - it can be fixed. PM for more details.
