Old 20-09-12, 06:51 AM   #1
MarkB852
Default LED indicators and resistors
At the risk of some abuse...
I've bought some LED indicators and separate resistors for the rear end of the bike. I will be getting the LED relay when I figure out what I'm doing at the front end but until then it's resistors.
They are branded as Alchemy and have two yellow leads on one side of the resistor and two black on the other. I was expecting just the two wires...
Has anyone got any experience of these? I could probably faff about until they worked but I'd rather go in with pictures!
Thanks,
Mark
Old 20-09-12, 07:45 AM   #2
sunshine
Default Re: LED indicators and resistors
just buy the relay, you can buy one that will work with if you put LED's on the front at a latter date, quickier easier and less messing around.
if you enjoy messing around, calculate the resistance difference between a standard indicator and the LED's then buy the necessary resistors from maplins. sorry i have no idea about 4 wire resistors.
Old 20-09-12, 08:39 AM   #3
Something like this, just plug & play. Works with both types I think
http://www.ebay.co.uk/itm/LED-flashe...ht_1864wt_1166
Or Oxford Nano indicators are well made, with resistors included, I've got them, they're great
Old 20-09-12, 10:09 AM   #4
Jayneflakes
Jayneflakes's Avatar
Just wire the LED lamps and Resistors together in parallel, then add to your loom. Simple. Make sure that you check polarity of your leads on the bike first, if you wire them the wrong way around, the LEDs wont light.
Jayne you're a Pussy Magnet
Old 20-09-12, 02:36 PM   #5
MarkB852
Thanks for all the replies, I think any future purchases will be Oxford LEDs...
Anyway. Online seller came back to me with a simple diagram that explained everything. The way it's designed is to ensure the resistor goes in parallel so it's two wires from the loom and two wires to the indicator. As I bought resistor and indicator from the same place they should plug straight in no problem.
Thanks,
Mark
Old 21-09-12, 01:43 PM   #6
tanis34
i've just fitted motrax led fire indicators to th front of my bike , and im well impressed by them
Backswept LED Indicators + Resistors rich88 For Sale - Other Bikes and General biking items 4 06-07-11 06:54 PM
resistors for indicators sv650nutter149 Stuff Wanted 2 08-02-09 08:39 PM
resistors for lED indicators Quiff Wichard SV Talk, Tuning & Tweaking 13 27-04-06 07:00 PM
LED indicators and resistors Warren SV Talk, Tuning & Tweaking 8 03-05-05 04:28 PM
Resistors for LED indicators? moodyman SV Talk, Tuning & Tweaking 8 07-02-05 10:44 PM
