Old 23-09-12, 05:09 AM   #1
dazuk
Default 2002 sv650 preload adjuster set up?
hi all when going over some bumps i get a clang from the front shocks i have looked at the preload adjusters and they are turned all the way in only one mark showing im currently 78kgs without my bike gear on what will be the ideal preload setting be?
thanks
darrell
Old 23-09-12, 06:36 AM   #2
speedyandypandy
Default Re: 2002 sv650 preload adjuster set up
how long is a rope, how big is a forrest.
Have you set the correct sag? Find a guide using google, there are many, find one using google.
Or
You adjust it to suit you, ride on a stretch of road you know well and test, go back to start of the same road, adjust and ride again, do this until you're happy with how the bike behaves, changing to a different oil, having a serviced/new damper and forks makes a lot of difference.
Old 23-09-12, 05:18 PM   #3
unclepoo
It sounds like the maybe the previous owner has set the pre-load to max or almost. There`s no point in having rock hard suspension on the road or if your not a heavy or aggressive rider. With the spring pre-loaded to the max the damping cant work and any bumps will go straight to your wrists. Try turning the adjusters all the way out on both sides, then wind them in by the same amount on both sides, leaving 4 marks showing on each adjuster...now go for a ride on a piece of road you know and see how it feels...you could take a screw driver with you and stop to make adjustments and try again. Lots of people will talk about changing oil weights or springs or even fitting a front end a gsxr and a rear shock from a zxr....but the standard setup is fine for road riding ..and if you wanted it to handle like a gsxr you`d buy one.
Old 23-09-12, 05:56 PM   #4
NTECUK
NTECUK's Avatar
Short term get a freind and set your sag.
Search how to set it up.
When you get time new oil and correct air gap . and if you can't get the right sag new springs.
Old 23-09-12, 08:52 PM   #5
ThePone
ThePone's Avatar
I didn't think an 02 model had adjustable preload on the front. Maybe the previous owner did a front end swap. If so why and is everything done up properly?
ThePone is offline   Reply With Quote
Old 23-09-12, 10:12 PM   #6
garynortheast
garynortheast's Avatar
02 model curvy did indeed have a pair of preload adjusters added to the forks.
http://www.alpha-sports.com/suzuki_p...FYcNfAodMUoAXA
garynortheast is online now   Reply With Quote
Old 24-09-12, 06:54 AM   #7
ThePone
ThePone's Avatar
My SK2 didn't. :-/
Old 24-09-12, 07:29 AM   #8
NTECUK
NTECUK's Avatar
Maybe it was robbed of then or a K1 late reg.
How does the SV650 cam chain adjuster work? Holdup SV Talk, Tuning & Tweaking 26 07-06-10 06:41 PM
Brand New Elka Gen 2 SV650 with Remote Hydraulic Preload sv-racing-parts For Sale - SV's and SV related items 0 03-12-09 01:02 AM
sv650 k3 clutch cable adjuster shiver85 Stuff Wanted 2 07-09-09 10:51 PM
Preload adjuster help scottjames SV Talk, Tuning & Tweaking 10 03-02-09 12:13 AM
will a 2002 sv650 s cylinder head fit my 99 sv650? bugsy46 Bikes - Talk & Issues 2 07-04-07 04:26 PM
