Old 20-10-12, 04:00 PM   #1
punkyp
Default K3 Radiator, engine bolt & original bar ends.
Looking for a radiator for a faired K, an engine mount bolt and original bar ends.
This happend to mine.
Old 20-10-12, 04:53 PM   #2
phil24_7
Default Re: K3 Radiator, engine bolt & original bar ends.
Good condition rads usually go for £75-£100 on here but rarely come up. The cheapest I've found new are here: http://www.aaronradiator.co.uk/catal...FUPHtAodwx8ArQ
Delkavic also sell K3 (faired) rads for £150 on ebay.
Don't overook the possibility of getting yours repaired. Take your rad, or the whole bike to a local radiator manufacturer and let them have a look, got mine repaired for £35+vat, mine was sligtly twisted and the end panel and been pushed in.
A set of R&G crash bungs come with that engine bolt if your interested!
Regards
Old 20-10-12, 05:26 PM   #3
punkyp
I have crash bungs on, this bolt comes from near the bottom, near the side stand. Not sure if I can just get one from B&Q or something.
Been looking at the rads there, is there 10% extra on top of that for org members?
Thought I'd try getting a used one before getting a new one. I'm skint atm, not sure what place could have a go at repairing mine.
Old 20-10-12, 06:06 PM   #4
phil24_7
Call a few breakers. These bolts rarely get touched and so rarely get broken. I doubt it's something they'd keep but if they are currently breaking one it should be quite cheap. Could also try seeing how much they are new (visit your local Suzuki dealer for them to bring it up on screen). Don't use one from a builders merchant as the properties wont be right for use on an engine mount in a motorcycle!
Why would they add 10% on???
If you type "radiators" and your location into google, then all you need to is email or phone the radiator repairers/manufacturers local to you and see what they say.
Regards
Old 20-10-12, 06:21 PM   #5
punkyp
http://www.sv650.org/adverts1/aaron/aaron%20rads.htm
I ment discount. Happen to know if that bolt is the same on a curvy? Local breakers only has a curvy atm.
Old 20-10-12, 06:48 PM   #6
phil24_7
Couldn't tell you for sure but I suspect they are different. Not sure about discount as they are already on sale but it never hurts to ask!
Regards
Old 22-10-12, 06:39 PM   #7
punkyp
Rad and bolt sourced. Thanks squirrel_hunter. Just the bar ends to go, hopefully they will cure the numb arm/vibration problem.
Original bar ends :) Beetrootkiller Stuff Wanted 11 23-08-12 08:00 PM
pro bolt bar ends + handle bar girps Gaz.sv650 For Sale - SV's and SV related items 5 22-05-12 10:28 PM
Pro-Bolt bar ends? daveyrach SV Talk, Tuning & Tweaking 11 18-09-11 05:48 PM
Urgent - Curvy Crash Bungs or Original Engine Bolt WeegieBlue Stuff Wanted 8 07-04-11 06:49 PM
Snapped Radiator Bolt. TheShadow SV Talk, Tuning & Tweaking 6 06-04-08 12:56 AM
