Old 22-10-12, 12:11 PM   #1
01 sv650s
Default Curvy low beam doesn't work.
hi, the headlights on my curvey packed up not long ago, they flicker on every now and then but i cannot find whats wrong with them. its not the bulbs and i checked the fuse and its fine, also my horn doesnt work dont know if it would have anything to do with it. also i put a a new battery in today, hasnt made any difference. my full beam works but no low beam, can anyone help? many thanks
Old 22-10-12, 12:25 PM   #2
NTECUK
NTECUK's Avatar
Default Re: curvy headlights wont work, please help
Search the forums .
Similar thing only 2 weeks ago.
Was the white wire on that one .
Old 22-10-12, 02:00 PM   #3
craig dow
hi , mine did the same 1999 curvie , right in the frount of the bike , right hand side is a plastic yellow connector check that , mine had a wee bit of rust on pins , cleaned them up , bit of wd40 and worked great , def sounds like a lose wire , good luck
Old 22-10-12, 02:31 PM   #4
daveyrach
Originally Posted by NTECUK View Post
Search the forums .
That was mine, twas the white wire from the left hand switch gear, metal connector were burnt and rusted, cut them and bypassed the connector, has been fine since. Mine is also a 1999 Curvy.
Old 22-10-12, 03:23 PM   #5
01 sv650s
many thanks to you all, ill have a look
Old 22-10-12, 06:49 PM   #6
farquare
Exact same issue with mine, clean and lubricate the pins and see if that solves the issues
Sent from my SK17i using Tapatalk 2
farquare is offline   Reply With Quote
Old 22-10-12, 09:40 PM   #7
From the previously mentioned thread:
Originally Posted by Sid Squid
If you're absolutely certain it's only the dip beam that's affected, then the fault is from the dip switch forward, therefore the problem is along the following line;
1) Dip switch
2) White wire from dip switch through left switchgear connector, into wiring harness and to fuse board
3) Fuse board and fuse holder
4) White wire from fuse board back to the bulb connector
5) Bulb connector
6) Any other connectors along that route that I can't think of right now
If you have the same problem as Davyrach did, in that the lights would flick on and off when the steering is moved, then the fault most likely lies in/around the area of the loom and connectors at the steering head and forward.
What fairings work on a curvy sv650? Sy-superfly SV Talk, Tuning & Tweaking 5 23-04-12 09:33 AM
H.I.D H4 for sv hi low beam ging6996 For Sale - SV's and SV related items 4 28-07-09 04:49 PM
low beam not working. Slash SV Talk, Tuning & Tweaking 3 26-09-08 02:28 PM
will a pointy reg/rec work on a curvy? weazelz SV Talk, Tuning & Tweaking 8 17-10-06 09:00 PM
