Old 26-10-12, 02:42 PM   #1
TCochrane
Default K3 - stiff ignition switch.
My SK3 650 has developed a problem where it is quite difficult to turn the key in the ignition. Including to steering lock.
I imagine it's probably caused by moisture or something in the ignition housing, but does anyone have any easy solutions?
Old 26-10-12, 03:13 PM   #2
Mark_h
Mark_h's Avatar
Default Re: Stiff ignition switch
They all do that. In general a forward pressure on the key (ie, push plastic bit towards front of bike) helps it. Also if you can obtain some graphite powder and put some in the key slot it can help.
Minister for Sustainability
Old 26-10-12, 03:15 PM   #3
TCochrane
Thanks Mark, if I don't have graphite paper could I just grind up a pencil or something? Seeing as its made of graphite.. or am I just being stupid?
Failing that - would WD40 work in small amounts?
Old 26-10-12, 03:22 PM   #4
Mark_h
Mark_h's Avatar
Best bet is to wait until you can get some graphite powder. It comes in a little squeezy bottle. You only need the smallest pot you can get as it'll last you about 600 years.
If you go squirting WD40, 3in1 or anything else down there it may help but will pretty much stop the graphite powder doing its thing.
Or do like the rest of us and get used to the key jiggle technique.
Old 26-10-12, 03:23 PM   #5
TCochrane
haha thanks, I'll use the key jiggle technique til I can get my hands on some graphite
Old 26-10-12, 03:32 PM   #6
Mark_h
Mark_h's Avatar
get it here or of course just replace your entire wiring loom and get a new lockset. Which ever you feel happiest with
SV ignition, key stiff to turn on. Dave_es94 SV Talk, Tuning & Tweaking 12 17-05-12 06:37 AM
4 wire ignition switch jaymee Stuff Wanted 0 28-05-10 04:14 PM
SV650s K3 Ignition switch fabz11 Stuff Wanted 0 04-04-10 06:55 PM
Failed ignition switch - again seedy100 SV Talk, Tuning & Tweaking 7 05-03-07 08:47 PM
Ignition Switch Tris SV Talk, Tuning & Tweaking 0 12-04-06 11:24 AM
