Old 07-11-12, 12:38 PM   #1
Scylla
Default Warning lights
My bike has CHEC on on the screen the other day.
Is this a warning that the oil is getting low or something?
Old 07-11-12, 12:47 PM   #2
Jayneflakes
Jayneflakes's Avatar
Default Re: Warning lights
This can flash up even if your bike is parked in gear when you switch on, it can also indicate other less obvious issues too. As far as I know, you have an oil warning light that will tell you if your oil level is low. The best bet is to manually check oil level though, then work through the rest.
I think that you can also put your bike into dealer mode and get a fault code that will tell you what is wrong if anything, however you will need to talk to others about how to do this or search threads on here.
Jayne you're a Pussy Magnet
Old 07-11-12, 01:16 PM   #3
timwilky
timwilky's Avatar
Wrong. The oil light is to indicate low oil pressure
Therefore if the light is not lit when you turn on the ignition you have a fault either in the sensor/wiring or blown bulb. Turning on the ignition is the one time you want to see the light. If it is on when the engine is running. Then Houston we have a problem
Not Grumpy, opinionated.
Old 07-11-12, 01:57 PM   #4
sputnik
Most common appearances of the Chec light are, as Jayneflakes says, bike in gear, or if the kill switch is still in the 'kill' position.
Old 07-11-12, 03:06 PM   #5
Jayneflakes
Oh wow, I feel like I have been corrected by my Dad! Can I tap you for some over due pocket money!? Also, my bedroom is not untidy, it is just that my stuff is filed differently!
On a slightly more serious note, When ever I have seen the chec sign it is because I have had the bike in gear with the side stand down or just not raised properly. Investigate the simple things before you start to worry too much or even discount it completely.
Old 07-11-12, 03:14 PM   #6
Spank86
It is a very good point though and something I always forget.
Old 07-11-12, 10:06 PM   #7
Scylla
Yep, It was in gear when the CHEC popped up again.
No side lights, brake lights, rear lights and dashboard lights Shona Bikes - Talk & Issues 25 13-11-09 11:07 PM
Cut Out / Hazard Warning Lights Mallet43 SV Talk, Tuning & Tweaking 2 29-10-09 02:01 PM
Weird indicator fault - they became hazard warning lights RingDing SV Talk, Tuning & Tweaking 5 24-01-09 09:05 PM
Why do people ignore warning lights? timwilky Idle Banter 12 18-05-07 06:01 PM
Warning lights jonnyt SV Talk, Tuning & Tweaking 2 12-05-06 12:09 PM
