Afternoon all,
I seem to have lost the bar end on right grip. I'm told this could be a common issue with the SV as it vibrates so much, has this happened to anyone else? If so, where did you source an OEM replacement from - I don't want to spend a fortune on them if it's going to keep happening. Thanks Dan |
Its usually the opposite, most bar ends are permanently attached as the screw gets rusted in place
There's quite a few pattern or similar ones made by Oberon on Ebay at next to nothing http://www.ebay.co.uk/sch/i.html?_tr...at=0&_from=R40 Don't but the ones with the expander bolt unless your bars aren't standard or have a rubber grommet with a nut inside it, sometimes these fall apart and the nut isn't held in place by the grommet any longer. SV's don't vibrate that much
Thanks guys - I've only had her 8 weeks so no chance of them being rusted in. Also, when I bought it - the shop fitted Daytona heated grips for me so I can only assume it wasn't done back up tight enough. Just checked the left and that was fairly loose too - so will look at the ones on eBay ending tonight. Quite like the purple ones too - they look sweet!
NOOOOOOOOOOOOOOOOO don't get the purple ones
Nooooooooooooooooooooooooooooo, don't listen to Maviczap, purple is an awesome colour!
#9 |
Sweet, won the auction for the adonised ones! Now, i'll make sure they're tight this time! They're alloy ones..
Bar ends !!!! | joshwalker094 | Stuff Wanted | 9 | 25-07-12 04:21 PM |
New bar ends | LK-SV | SV Talk, Tuning & Tweaking | 1 | 01-02-10 06:10 PM |
Screws for Bar ends/ bar ends, black screen K3 Pointy | renman8957 | Stuff Wanted | 3 | 06-02-09 06:08 PM |
Bar ends | AndyBrad | SV Talk, Tuning & Tweaking | 7 | 02-09-08 04:16 PM |
Bar Ends | Phantomtek | Stuff Wanted | 8 | 18-08-08 09:37 PM |
