Old 02-02-13, 08:41 PM   #1
DanSp
Default Indicators work, hazards don't work properly.
This has been puzzling me all day for no other reason than i can think of no real reason for it to happen... All of my indicators work correctly when used with the switch on the LH switchgear however when i put the hazards on only the right indicators (both front and rear) come on...
Any thoughts anyone!?
Old 02-02-13, 08:45 PM   #2
DJ123
DJ123's Avatar
Default Re: Indicator / Hazard issue
Mine did this a little while back. Checked the relay was in correctly and sprayed some contact cleaner into the RH switch gear. Next day everything was fine and has been since!
Not much help i know, check connections and spray some contact cleaner in the RH switchgear. It may help!
BMW F800ST
Old 03-02-13, 10:52 AM   #3
jambo
jambo's Avatar
Pull out a wiring diagram and look for the connectors that are used exclusively by the hazard switch.
You know the indicators, and wiring back to the indicator switch is good, but you may have a dirty switch contact or connector that's only used by the hazard switch to bring them both in together.
Lazy first attempt would be to spray some contract cleaner or wd40 into the switch housing and press the hazard button a couple of dozen times and see it'd that cleans up the contracts.
Jambo
Jambo
Sent from my thingie
Last day at work Ed Idle Banter 7 30-03-11 04:29 PM
Indicators not working properly. 999birdie SV Talk, Tuning & Tweaking 3 15-10-10 05:19 PM
Indicators - work with alarm but not by the switch. asteer17 SV Talk, Tuning & Tweaking 14 06-11-09 11:19 AM
Getting to work stroppygob Bikes - Talk & Issues 22 09-03-09 10:54 PM
Anyone work for BT? El Saxo Idle Banter 9 12-02-09 11:46 PM
