Old 04-03-13, 04:20 PM   #1
dirtyred619
Default 320mm Brake Discs for GSXR 750 Calipers/Speedo Issue
I'm going to be needing new brake discs for when I put the GSXR front end on and was hoping to buy a new set of the Black Shadow ones as they're a reasonable price and a few people on here have said they're decent. But from what I can see they have either 7 or 9 rivets which will be no good when it comes to sorting the speedo issue out.
So I need other suggestions please. I'd rather buy new but can't really stretch to much more than the Black Shadow ones cost at the moment but am also a bit cautious on buying second hand (unless it's of one of you guys!). I've seen these http://www.ebay.co.uk/itm/1907988966...84.m1438.l2649 which will do the job and sent the seller a few questions about condition, thickness left, warped etc. If he gives me the right answers back is he asking a fair price?
Or failing that, would there be another way of getting arouond the speedo problem with the Black Shadow discs? I know Lance has come up with a nice tidy solution that works of the back wheel but seems to be a bit quiet at the moment.
Old 04-03-13, 04:55 PM   #2
Blueperson
Default Re: 320mm Brake Discs for GSXR 750 Calipers/Speedo Issue
You can fit a speedo pick-up to your front sprocket setup, as well as the back wheel.
£100 seems a bit salty for used discs.
Old 04-03-13, 07:18 PM   #3
dirtyred619
Could you elaborate. Was going to fit a Hall effect sensor and 4 magnets evenly spaced but the problem being getting the magnets evenly spaced out.
Old 04-03-13, 07:46 PM   #4
dirtyred619
And the guy reckons they're 100% straight and 5mm so virtually no wear. What would be a reasonable price then?
Old 05-03-13, 10:31 AM   #5
dirtyred619
Just looking at the 10mm magnets to go into the sprockets on the brakes, does it matter what depth they are or can I just mount them flush with araldite? Ta.
Cheap SRAD / TL / 'Busa 320mm discs fastdruid For Sale - Other Bikes and General biking items 2 06-03-10 06:17 PM
GSXR 320mm Front Discs svdemon Stuff Wanted 13 31-05-09 01:17 PM
Pumping 4 Pot Calipers (SV/GSXR Brake Swap) squirrel_hunter SV Talk, Tuning & Tweaking 7 27-04-07 10:40 PM
Recent Hondas with 310mm or 320mm discs? northwind Bikes - Talk & Issues 12 07-03-07 03:54 PM
Brake Discs for GSXR front end conversion on SV 320mm discs Ter For Sale - SV's and SV related items 0 22-09-06 04:50 PM
