Old 04-03-13, 07:10 PM   #1
jandn1
Default Naked brake lines fit faired bike?
Hi
Will standard length N model SS front brake lines be the right length to replace originals on a S model that i am fitting a CNC top yoke onto and are they the same fittings?
Nik
Old 04-03-13, 07:35 PM   #2
Nicky S
Nicky S's Avatar
N brake lines are longer then S lines as on a N you have bars and on a S you have clip ons that are lower.
The York should not really make a diffrence as it will be the same as the OEM one.
On the size of the fitting (bango bolt) I'm not sure if they are the same on each model as they have diffrent master cyclinders.
Curvy With Lots Of Bits ...
But Still More To Come
Nicky S is offline   Reply With Quote
Old 04-03-13, 07:48 PM   #3
jandn1
Default Re: SS Front Brake Line length
Thanks for the reply Nicky
I realise the N has longer hoses i am just questioning if they will be long enough to accommodate going from standard clipons on the S to the CNC Top Yoke which is a conversion to give straight bars as on the N model. I recon i will need an extra 4" over the standard S length but not able to find any readings for N model against S model lengths.
Old 04-03-13, 08:59 PM   #4
Nicky S
Nicky S's Avatar
Ohhh I see I misunderstood your post. As you say the S pipes will not be long enought.
Did the conversion not come with brake lines or throttle cables ??
I'd say that they will not make it. When on full lock.
Old 04-03-13, 09:08 PM   #5
Nicky S
Nicky S's Avatar
Iv looked for the lengths of the lines but can't find anything.
But I do know you can get longer ones for what you are doing
Old 04-03-13, 09:30 PM   #6
jandn1
Its a second hand yoke and bars so no brake lines included.
Yep i am thinking get some S model lines with an extra 4"?
Old 04-03-13, 10:38 PM   #7
Elliott
I've done it on mine. Uses "n" model brake lines.
Goodridge brake line length, faired/naked? Robust2 SV Talk, Tuning & Tweaking 6 24-12-12 02:10 PM
Front brake hoses for naked fit faired bike? pie_master SV Talk, Tuning & Tweaking 1 03-05-12 10:25 AM
Turning a naked into a faired bike Fifteen15 SV Talk, Tuning & Tweaking 4 22-08-11 11:46 AM
Rear Brake hose length - Naked vs Faired DarrenSV650S SV Talk, Tuning & Tweaking 4 11-03-09 08:15 PM
Faired clocks on a naked bike (curvey) trudd SV Talk, Tuning & Tweaking 0 22-04-07 08:12 PM
