Old 04-03-13, 08:43 PM   #1
sheepracer
Default GSXR K6 Shock in Curvy?
Well fitted the shock, needed to cut the airbox and move a few bits,but the bike is now sat on its ****!! about 4 inches lower than standard???
Checked the mounting points and shock length is pretty much like for like!
Any ideas??
Chris
Old 04-03-13, 08:54 PM   #2
Nicky S
Nicky S's Avatar
Air box do you mean battery box ?? Have you put the shock to its high setting?
When looking at the shock your see a metal ring that has chunks chopped out of it this rises and lowers the shock.
Picture explains it better sorry
Also is the shock in working order ?? The shock might be faulty. Not holding the pressure.
Curvy With Lots Of Bits ...
But Still More To Come
Nicky S is offline   Reply With Quote
Old 04-03-13, 09:09 PM   #3
dkid
Default Re: GSXR K6 Shock in Carby Help!
Is that not just the preload adjustment? Don't think it alters the distance between mounting points.
OP, Which shock do you have specifically? GSXR 600, 1000 etc? Every gixxer shock from that year is shorter than standard as far as I can see. A 10mm shorter shock will lower the rear at the tail by around twice that amount I think.
Check out this chart
https://docs.google.com/spreadsheet/...COvG24gH&pli=1
Old 04-03-13, 11:42 PM   #4
Take the shock off, measure it's length between centres of mounting holes, if it's more than a few millimetres longer or shorter than the standard shock it's not really suitable.
Old 05-03-13, 07:17 AM   #5
Nicky S
Nicky S's Avatar
That's true.
Curvy too low after changing to GSXR shock. alfa.rbt SV Talk, Tuning & Tweaking 28 17-06-12 08:20 PM
Which GSXR shock for my Curvy? bigchris SV Talk, Tuning & Tweaking 8 21-05-12 09:08 PM
gsxr 750 srad shock rubs on curvy swingarm, help? leebex SV Talk, Tuning & Tweaking 22 21-11-10 09:02 PM
K5 gsxr thou shock going onto k5 pointy - will I need the lower gsxr shock bolt? Paul the 6th SV Talk, Tuning & Tweaking 37 31-10-08 12:26 AM
GSXR 600 2006 shock on curvy Jussi SV Talk, Tuning & Tweaking 0 29-10-06 04:23 PM
