Old 01-04-13, 09:15 PM   #1
scottp_15
Default Pillion peg spacer and bolt
Anyone got a spare of the above I could buy? Attached a pic just to clarify
Old 03-04-13, 08:02 AM   #2
scottp_15
Default Re: Pillion peg spacer and bolt
Bump.
Old 03-04-13, 08:51 AM   #3
Looks like an aftermarket one, supplied with the exhaust headers mate.
I have similar spacers with my Micron headers.
You could get some tubing & long enough bolts to make up a similar spacer from somewhere like B&Q
Unless you know who made the exhaust?
Old 03-04-13, 09:09 AM   #4
scottp_15
Yeah it's a scorpion exhaust but unfortunately it only had one spacer with the pegs. Phoned the guys I bought it from and they don't know where it is (fantastic).
Any idea where to look for the tubing? I haven't had any look at department stores, nothing is thick enough.
Old 03-04-13, 10:22 AM   #5
B&Q?
If not a proper Ironmongers
Ebay?
Old 04-04-13, 03:13 PM   #6
nikon70
any good?
or this?
Old 04-04-13, 06:33 PM   #7
scottp_15
Unfortunately not, it needs to be 8mm internal diameter and 20mm external diameter. Been trying to find something for ages
Old 04-04-13, 06:59 PM   #8
Geodude
Geodude's Avatar
Probably a daft reply on my part but have you tried contacting scorpion to see what they can do?
Old 04-04-13, 07:30 PM   #9
See if a local engineering company can machine a couple up for you, so that they match.
Its a simple job for an apprentice
Old 05-04-13, 08:46 AM   #10
nikon70
Can't be that hard
http://www.steelexpress.co.uk/
or this then just drill out the center
or this 16mm OD x 10mm ID - is stick a washer both side to make it 20mm ??
SV650S Barends, pillion peg bolts & infill bolt. phil24_7 Stuff Wanted 6 04-03-13 04:46 PM
sv650 k6 rear wheel disc spacer +bearing center spacer. jacknell Stuff Wanted 0 01-06-11 07:11 PM
Pillion peg mounting bolt size? Shaun. SV Talk, Tuning & Tweaking 2 31-03-11 07:08 PM
Lower Fairing Top bolt gromet and spacer DF! Stuff Wanted 2 20-09-08 05:06 PM
Bolt: Can / Pillion footrest MiniMac Stuff Wanted 2 01-05-08 07:23 AM
