Old 22-04-13, 02:33 PM   #1
Xpistos
Default Which chain and sprockets? Pointy.
Hi Guys,
In deperate need of a new chain and sproket for my SV650s, had a quick look and came across a few, anyone mind reccomending one?
Link 1
Link 2
Link 3
Also if you've got any better suggestions please feel free to let me know, price is a big objective, but i dont want to loose out on too much quality.
Thanks In advance
Chris.
Old 22-04-13, 02:42 PM   #2
muzikill
muzikill's Avatar
Default Re: Chain And Sprocket
Wemoto chain & sprocket kits. I tried to do the ebay thing & didnt have any faith in what they were going to sell me.
Old 22-04-13, 02:50 PM   #3
Pricey12
Give B&C Express a try:
http://www.bandcexpress.co.uk/
Old 22-04-13, 04:07 PM   #4
garynortheast
garynortheast's Avatar
Try this, it's what I've just fitted. The chain they supply is a black and gold one. http://www.bitzforbikes.co.uk/DID_VX...-2522-513.html
Old 22-04-13, 04:22 PM   #5
Those you link are cheap crap... all except for the JT sprockets bit. JT are decent.
DID VX is economy grade chain, but will be better than the no-name rubbish.
Do you want cheap, or value for money?
Old 22-04-13, 04:37 PM   #6
Fallout
Fallout's Avatar
I've changed two chain and sprocket sets. SV and Gixxer. Both were DID. SV did about 3000 before sale. Gixer has done about the same. Not long enough to give a true indication of quality, but neither needed adjusting nor has developed any problems and all have been brutally mercilessly thrashed.
Conclusion: DID seem fantastic and good value for money (also do a rivetting tool in many ebay kits), but may explode at 3001 miles. No way to be sure.
MotoGoLoco - You knows it
Fallout Breakbeat (My Music)
Old 22-04-13, 06:36 PM   #7
LewSpeight
LewSpeight's Avatar
take note of this thread
Old 23-04-13, 08:05 AM   #8
Xpistos
Default Re: Which chain and sprockets?
Honestly, cheap value for money would be best
I know its unlikely though, I want to spend around £100 all in, so the best for that sort of value.
The third Link I posted with the JT sprockets looks good to me, the chain cant be that bad can it?
Theres also several ebay posts with DID chains safe to assume one fo them is good, I've used a DID chain before and it was fine.
Old 04-03-14, 10:38 AM   #9
Markos_46
Rather than start a new thread on this - quick question, what's the difference between a kit for a pointy SV650s 03-07 & for 08-10?
Old 04-03-14, 11:35 AM   #10
jambo
jambo's Avatar
I believe the S moved to a 45 tooth rear. Same chain & front sprocket, +1 on the back vs the 44 tooth that was there before.
Either would fit, just a slight down gearing.
But I could be wrong.
Jambo
Which chain and sprockets? svrich SV Talk, Tuning & Tweaking 21 07-05-12 07:46 PM
Chain and sprockets sunshine SV Talk, Tuning & Tweaking 6 01-03-10 10:38 PM
Chain&Sprockets stevie SV Talk, Tuning & Tweaking 4 23-08-07 07:10 AM
New chain and sprockets dmracing SV Talk, Tuning & Tweaking 3 01-05-07 03:50 PM
new chain and sprockets adam_castell SV Talk, Tuning & Tweaking 12 23-10-06 03:38 PM
