Old 14-05-13, 05:47 PM   #1
daveyrach
Default Battery or charging fault? Curvy.
So went to leave work and bike turned over a couple of times then slowly died. I am confidently assuming it is the battery. I had a new reg/rec about 18 months ago but the symptoms when it broke down were completly different, on that occasion it died completely this time all the lights work and will attempt to turn when left for a few minutes.
Lucky one of my colleagues rides a Triumph Daytona so I rode pillion home.
Whats everyone else think?
Sent from my Galaxy S2 using Tapatalk
Old 14-05-13, 05:48 PM   #2
daveyrach
Default Re: Electrical Issue
PS. Already bought a new battery.
Old 15-05-13, 06:33 AM   #3
Spanner Man
Good morning.
Get it started, & check it's charging ok.
Cheers.
Spanner Man
Old 15-05-13, 06:48 AM   #4
daveyrach
Remind me where to check and the voltages. I have done before with the reg/rec but cant remember. Cheers
Old 15-05-13, 06:56 AM   #5
Geodude
Geodude's Avatar
Have a work through this Fault finder its quite a good one. HTH
Old 15-05-13, 07:01 AM   #6
daveyrach
Cheers Geo that's the one I used last time.
Old 15-05-13, 07:08 AM   #7
Geodude
Geodude's Avatar
No probs Davey Have a look at my charging thread or the below quote from my thread as it might be of some help.
Right todays adventure may have sorted it but also showed how daft i maybe at the same time..
Ignition off battery 12.7
Idle lights on +14v
Rev 5k lights on 13.8 to 14v
This was achieved by running a wire from the black wire on reg/rec to the -ve on the battery so it looks like it was a bad earth or wire somewhere Is it safe to keep this wire permanently attached now as it seems to work?
Old 15-05-13, 07:31 AM   #8
daveyrach
How do these figures look, new battery fitted in the work car park and I get the following:
Ignition off 12.7v
Idle 13.8v
Old 15-05-13, 07:40 AM   #9
Geodude
Geodude's Avatar
Do rev test with lights on at 5000rpm what volts you get then?
Old 15-05-13, 07:46 AM   #10
daveyrach
I did that it was 12.9v which according to that guide is fine.
Just checked the old battery I took off that is putting out 12.1v, does this mean faulty?
Curvy charging fault? Pricey12 SV Talk, Tuning & Tweaking 8 12-03-13 01:56 PM
Charging or battery fault. Crash Bandicoot Bikes - Talk & Issues 4 29-12-11 08:27 PM
Electrical fault - Battery not charging properly ShadFX SV Talk, Tuning & Tweaking 28 25-08-11 03:37 PM
Curvy charging/battery problem. radicalry00 SV Talk, Tuning & Tweaking 13 04-01-10 05:38 PM
Charging fault? emcf SV Talk, Tuning & Tweaking 10 28-11-09 03:03 PM
