Old 21-05-13, 07:49 AM   #1
Mark_h
Mark_h's Avatar
Default SV1000 range after yellow light
I've got a K3 SV1000 with various induction and exhaust mods. I usually get 112 miles from full to yellow light with "spirited" riding. I've always assumed I've got a bit in reserve but look for fuel ASAP.
Sunday I left Reading with my yellow light on. 16 miles to home so thought I'll be fine. Fill up when I get home.
Riding around the Reading ring road the bike died on me a couple of times. Managed to restart and rode it into a petrol station well actually coasted into a petrol station as it had died completely by then.
I doubt I did more than 10 miles with the Lamp on.
Anyone got any experience of how far you've got on a fuel warning on a K3SV1000? I'm not sure if my sender is a bit off or perhaps I've just always ben very lucky not to run out.
For those unaware, the K3 has a 1 stage LED. LED off, LED on, Push bike to petrol station. I discovered this when I first got the bike and wondered how many miles it was between on and flashing.
Minister for Sustainability
Old 21-05-13, 08:30 AM   #2
pookie
pookie's Avatar
Default Re: SV1000 range after yellow light
I've managed an extra 25 - 30 miles on a commute home leaving the city and then along big a roads. I reckon there was more mileage in the tank. My light would come on 110 -118 ish. I dont brim the tank more like chuck the nozzle in and twist a little and stop filling up when it splutters.
Old 21-05-13, 09:09 AM   #3
Cymraeg_Atodeg
The reserve light is supposed to be 3ltrs of fuel, so, I should be about 30 miles from my Thou', but, have always filled up after 20-odd
As far as I am aware all SV1000's have a on/off fuel light, there is no blinking.
Old 21-05-13, 09:40 AM   #4
rictus01
rictus01's Avatar
like the main tank volume; the right hand can have a major effect on the mileage you get from reserve, however unlike the main bit the reserve also accumulates water and debris that can reduce this, it maybe worth flushing the tank and seeing what comes out the bottom.
Cheers Mark.
Old 21-05-13, 09:46 AM   #5
There is no physical reserve... it still sucks from the bottom of the tank all the time. Doubt there can be much in there that could reduce volume without plugging the filter unless you have achild been dropping marbles in there or something.
Old 21-05-13, 10:37 AM   #6
aesmith
So the old trick of lying the bike down on it's side after you run out doesn't work any more?
Old 21-05-13, 01:29 PM   #7
SuzukiNess
I've been caught out 3 times with fuel light on to empty haven't yet figured out how many miles left after the light comes on because it ranged from 20 to 10.... so its find the nearest fuel stop pdq
Old 21-05-13, 02:43 PM   #8
Yeah it might as it still might slurp a bit extra but remember on these efi's you need fuel in the pump... there is no float bowl that it can run into... the fuel pump needs to be fully primed to give pressure to the rest of it.
so it can work a bit, but not like on a carby.
Range from fuel light? K3 granty92 Bikes - Talk & Issues 9 12-02-13 12:47 AM
White light VS Yellow headlights? Thaleshwar Bikes - Talk & Issues 9 26-04-12 04:45 PM
Yellow Ermax Undertray for 2003+ SV650 or SV1000 ian505050 For Sale - SV's and SV related items 0 16-04-10 09:10 PM
Curvy RHS Panel 02 (Light Yellow) Kris 101 Stuff Wanted 8 17-12-09 11:10 PM
Range with fuel light on? speedplay SV Talk, Tuning & Tweaking 11 24-02-09 12:03 PM
