Old 11-06-13, 09:49 AM   #1
Kermit650
Default Throttle cable differences - K6/K7 ?
Is there any difference between the throttle cables in these two years?
Been in contact with venhill for a quick action throttle they have only ever done upto k6 and don't know if there is any difference.
Thanks
Kermit.
Old 11-06-13, 09:46 PM   #2
madcockney
Default Re: Throttle cable differences - K6/K7 ?
According to the online Suzuki catalogue at Alpha.com the K6 and K7 for the S have the same part number 58300-16G10, However I suggest that you check for yourself.
madcockney is offline   Reply With Quote
Old 11-06-13, 09:48 PM   #3
Kermit650
I have the naked, which I know has longer cables than the S model.
Will have to do some more digging about.
Thanks
Old 11-06-13, 10:00 PM   #4
madcockney
If the S years are the same then I am sure that the naked will be also, If you go to Alpha.com, click on Suzuki and then follow the instructions you will find the part numbers to compare. The throttle cable Assy for the naked is under handlebar no cowl
Throttle cable broken? kellyjo Bikes - Talk & Issues 8 04-10-12 10:33 AM
Throttle Cable help hindle8907 Bikes - Talk & Issues 7 28-12-11 01:46 PM
k5 throttle cable help??? ben650 SV Talk, Tuning & Tweaking 2 21-01-08 11:40 PM
Throttle Cable M65 SV Talk, Tuning & Tweaking 5 23-06-05 08:48 AM
