Old 01-07-13, 12:21 PM   #1
JLeo
Default Removing seized baffles?
So basically I don't think these baffles from a Blue Flame Evo exhaust have ever been removed (5 years or more) so they seem to be seized in.
Any suggestions on how to get them out without ruining them?
Old 01-07-13, 12:26 PM   #2
stuR
Default Re: Removing seized baffles??
ive alwayd used pliers with a bit of cloth either side if they have an edge like the fuel baffle.
Old 01-07-13, 12:28 PM   #3
JLeo
Default Removing seized baffles??
Yeh that's what I've been using, but its got to the point where I feel I'm going to pull the whole exhaust off! They just wont budge, haha
Old 01-07-13, 12:31 PM   #4
stuR
Try a squirt of penetrating oil of wed40 around the edge to loosen maybe?
Old 01-07-13, 12:31 PM   #5
JLeo
Ok cheers il give that a go
Old 01-07-13, 12:45 PM   #6
TamSV
TamSV's Avatar
Take the can off and knock the baffle out from the inside with a broom handle.
Old 01-07-13, 06:01 PM   #7
PyroUK
PyroUK's Avatar
Mate has a similar predicament at the moment.
Garage said easiest way to sort it is to drill or cut the old bolt out/off depending on how good access is.
You can always replace the bolt.
Hth
2011 Triumph Daytona 675, Arrow exhaust and QS!
PyroUK is offline   Reply With Quote
Old 01-07-13, 06:13 PM   #8
Lozzo
Pipe grips and a hammer. Clamp the grips to the outer edge of the baffle with the handle pointing away from the can, then hit the handle with an 'ammer towards the back of the can. They'll come out quick enough.
Just to make sure, you have actually removed the securing bolt?
Old 01-07-13, 06:20 PM   #9
PyroUK
PyroUK's Avatar
Oh yeah my bad misread, thought you said the bolts were seized! If they aren't ignore what I said.
If it is just the baffle, have you got a portable heat source like a blow torch? If so and you can get hold of some compressed air like a computer air can you can try the heat/cold trick. You will likely need a mate.
Heat the outside if the can near where the baffle is seated, not on the area but near, do the whole circumference if you can and gently heat it up. Then get a decent pair of mole grips on the baffle and spray the compressed air on the baffle and get your mate to give it a good tug. If it doesn't go straight away a few taps with a hammer on the baffle should help to loosen and grime in the way and repeat the process.
Old 01-07-13, 09:11 PM   #10
JLeo
Cheers people for the responses. Managed to get them out... (Wd40 and some grips) she now sounds gorgeous!!
Where can I buy baffles? SUPERSTARDJ01 Bikes - Talk & Issues 6 06-05-11 08:26 AM
baffles out davepreston SV Talk, Tuning & Tweaking 13 31-03-10 10:08 AM
Baffles? SUPERSTARDJ01 SV Talk, Tuning & Tweaking 5 11-05-09 01:39 PM
Removing the Baffles Lafgr8 SV Talk, Tuning & Tweaking 21 17-07-08 08:45 PM
removing baffles nick the greek SV Talk, Tuning & Tweaking 4 01-04-07 03:09 PM
