Old 26-07-13, 10:27 PM   #1
rapidgaz
rapidgaz's Avatar
Default Power commander for 12/13 model?
Hi does any 1 know if they do a power commander or two brothers fuel commander for a l2/l3 model year, and are they worth using.
Cheers.
rapidgaz is offline   Reply With Quote
Old 27-07-13, 09:45 AM   #2
sniff
sniff's Avatar
Default Re: Power commander for 12/13 model?
Power commander without a doubt. Never had TB exhaust so can't comment on that bit.
Forgot to add it should be a PCV same as on my K9
sniff is offline   Reply With Quote
Old 27-07-13, 01:16 PM   #3
my suggestion (not that that matters), don't bother unless you have a very modified SV that needs the fuelling messed with. a standard SV even with a can and filter all you will be doing is moving the curve around. yes you might feel a difference but in reality there will be no more/very little extra horses produced.
save the cash and spend it on things that matter like tyres and servicing. unless your mega loaded then bash on.
Old 27-07-13, 06:51 PM   #4
rapidgaz
rapidgaz's Avatar
Cheers fellas. No not loaded. Wish I was lol. Getting a scorpion carbine extreamy thingy can. May get a filter to when I've done a few more miles. May just leave it then.
Old 29-07-13, 12:20 PM   #5
SV650Racer
You would be surprised. We had an Org member in two weeks ago, just an end can and his bike was fueling very rich. Mapped the ecu and gained him a few BHP but ultimatly alot smoother ride and an extra 20 odd miles to the tank!!
You arent moving the curve around when fueling the bike, your optimising the fueling which will ultimatly make some changes to the curve but will give you a bike that fuels as it should, ride alot nicer and not eat gallons of fuel and spit it straight back out again!
Old 29-07-13, 12:45 PM   #6
did you use a PC or map the bikes ECU?
Old 29-07-13, 01:18 PM   #7
SV650Racer
Mapped the ecu directly using the pro bike software which has more range than the yoshi/teka box.
Works really well. PC5 has even more scope than the pro bike software and is ideal if you dont have a dyno nearby that uses the pro bike software or are running a tuned engine etc.
Healtech FI Tuner Pro is also recommended as plugs direct to the diagnostics plug and can be custom mapped on the dyno using the supplied software - one advantage over the PC5 is if you change your bike for another Suzuki the FI Tuner will unplug and then plug into any other Suzuki that has a diagnostics plug..
Most bikes we see come in are running rich when decatted - Triumphs though tend to run off very very lean low down.
Old 29-07-13, 04:15 PM   #8
rapidgaz
rapidgaz's Avatar
What's the chances of me having to do any changes after fitting the scorpion end can.
Old 29-07-13, 04:27 PM   #9
SV650Racer
TBH you wont know until you get an air fuel run done on a dyno to be 100% sure. Even stock bikes benefit from a proper fueling map as no two bikes will require the same fueling map..
You wont be a mile out though, certainly not enough to be causing an issue if you dont have a running problem..but it all comes down to budget and whether you want to get the bike running as best it can or if MPG is a major concern.
Old 29-07-13, 04:30 PM   #10
none.
i have Beowulf, K&N and cut down snorkel and my bike runs just fine.
ask yourself a couple of serious questions.
do you do a lot of track days?
can you rag the titzz out the bike everywhere?
does your bike run like a pile of poo?
Power Commander, power increase? sephy666 SV Talk, Tuning & Tweaking 1 20-02-11 09:59 AM
Power Commander for a K4 650 Dr.Tom Stuff Wanted 10 28-06-10 08:47 PM
Power commander set up Gracie SV Talk, Tuning & Tweaking 2 02-07-07 08:32 PM
power commander usb 3 for k3 and above sv650nutter149 For Sale - SV's and SV related items 0 21-06-07 07:15 PM
Power Commander power graph print outs. JimPSV SV Talk, Tuning & Tweaking 19 27-11-06 09:39 AM
